주요 콘텐츠로 건너뛰기
HP 15-ac121dx Screen Replacement
필요한 것
  1. HP 15-ac121dx Screen  Replacement, Battery: 1 단계, 이미지 1/1
    • Remove all external devices from the computer.
    • Remove the charging cord from the computer.
  2. HP 15-ac121dx Screen  Replacement: 2 단계, 이미지 1/1
    • Turn off the computer by holding the power button.
  3. HP 15-ac121dx Screen  Replacement: 3 단계, 이미지 1/2 HP 15-ac121dx Screen  Replacement: 3 단계, 이미지 2/2
    • To remove the battery, slide the left slider on the back to the unlocked position.
  4. HP 15-ac121dx Screen  Replacement: 4 단계, 이미지 1/2 HP 15-ac121dx Screen  Replacement: 4 단계, 이미지 2/2
    • Push the right slider inwards.
    • Remove the battery out by pulling straight out and to the right.
  5. HP 15-ac121dx Screen  Replacement, Screen: 5 단계, 이미지 1/1
    • Open the laptop so that the screen is facing you.
  6. HP 15-ac121dx Screen  Replacement: 6 단계, 이미지 1/2 HP 15-ac121dx Screen  Replacement: 6 단계, 이미지 2/2
    • With the screen facing you, use the plastic opening tool to remove the liner around the screen
  7. HP 15-ac121dx Screen  Replacement: 7 단계, 이미지 1/1
    • Using a Phillips #000 screwdriver, remove all four 2mm screws in each corner of the screen.
  8. HP 15-ac121dx Screen  Replacement: 8 단계, 이미지 1/2 HP 15-ac121dx Screen  Replacement: 8 단계, 이미지 2/2
    • Carefully remove the screen and place it face down on the keyboard.
    • Do not pull the screen away from the front panel assembly, as this would damage the cord connecting the screen to the front panel assembly.
  9. HP 15-ac121dx Screen  Replacement: 9 단계, 이미지 1/2 HP 15-ac121dx Screen  Replacement: 9 단계, 이미지 2/2
    • With the screen faced down on the keyboard, remove the grounding tape adhered to the back of the screen.
    • You should see a 36-pin plug underneath the grounding tape.
    • Carefully remove the 36-pin plug, not to damage the grounding tape or the plug.
결론
Keefe White
회원 가입일: 09/30/19
121 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 9
전체 시간: 773
