주요 콘텐츠로 건너뛰기
HP 15-ac142dx Battery Replacement
필요한 것
  1. HP 15-ac142dx Battery Replacement, Battery: 1 단계, 이미지 1/2 HP 15-ac142dx Battery Replacement, Battery: 1 단계, 이미지 2/2
    • Turn off the computer and flip it upside down and place on a flat surface
    • Push the battery lock on both sides, sliding them to each other, to unlock the battery
    • Lift the battery from the center and remove
  2. HP 15-ac142dx Battery Replacement: 2 단계, 이미지 1/1
    • Take the new battery and line it up with the slot.
    • Insert it in and when you here a click you will know it is in place
결론
Nicole Mathieu
회원 가입일: 03/19/18
620 평판
안내서 5개 작성하였습니다
UMass Dartmouth, Team S2-G4, Bernier Spring 2018 UMass Dartmouth, Team S2-G4, Bernier Spring 2018 회원
UMASSD-BERNIER-S18S2G4
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 5
전체 시간: 422
