주요 콘텐츠로 건너뛰기
HP 15-ac142dx CD Drive Replacement
필요한 것
  1. HP 15-ac142dx CD Drive Replacement, CD Drive: 1 단계, 이미지 1/3 HP 15-ac142dx CD Drive Replacement, CD Drive: 1 단계, 이미지 2/3 HP 15-ac142dx CD Drive Replacement, CD Drive: 1 단계, 이미지 3/3
    • Turn off the computer and flip it over onto a flat surface.
    • Remove battery by sliding the battery lock.
    • Remove the 10 screws
  2. HP 15-ac142dx CD Drive Replacement: 2 단계, 이미지 1/2 HP 15-ac142dx CD Drive Replacement: 2 단계, 이미지 2/2
    • Flip the computer back over and use the iFixit tool in order to pry the keyboard from the bottom of the computer.
    • Once off you will be able to see the CD ROM.
    • Slide the CD Drive out of the device.
    • It will be located on the bottom half of the computer.
결론
Nicole Mathieu
회원 가입일: 03/19/18
620 평판
안내서 5개 작성하였습니다
UMass Dartmouth, Team S2-G4, Bernier Spring 2018 UMass Dartmouth, Team S2-G4, Bernier Spring 2018 회원
UMASSD-BERNIER-S18S2G4
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 374
