주요 콘텐츠로 건너뛰기
HP 15-ac142dx Motherboard Battery Replacement
필요한 것
  1. HP 15-ac142dx Motherboard Battery Replacement, Motherboard Battery: 1 단계, 이미지 1/3 HP 15-ac142dx Motherboard Battery Replacement, Motherboard Battery: 1 단계, 이미지 2/3 HP 15-ac142dx Motherboard Battery Replacement, Motherboard Battery: 1 단계, 이미지 3/3
    • Turn off the computer and flip it over onto a flat surface.
    • Remove battery by sliding the battery lock.
    • Remove the 10 screws
  2. HP 15-ac142dx Motherboard Battery Replacement: 2 단계, 이미지 1/2 HP 15-ac142dx Motherboard Battery Replacement: 2 단계, 이미지 2/2
    • Flip the computer back over and use the iFixit tool in order to pry the keyboard from the bottom of the computer.
    • Once off you will be able to see the mother board battery.
    • Remove the battery.
    • The battery should be able to be easily removed just by hand
결론
Follow previous instructions in reverse order to reassemble the device .
다른 한 분이 해당 안내서를 완성하였습니다.
Nicole Mathieu
회원 가입일: 03/19/18
620 평판
안내서 5개 작성하였습니다
UMass Dartmouth, Team S2-G4, Bernier Spring 2018 UMass Dartmouth, Team S2-G4, Bernier Spring 2018 회원
UMASSD-BERNIER-S18S2G4
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 7
전체 시간: 766
