주요 콘텐츠로 건너뛰기
HP 15-ac142dx Screen Replacement
필요한 것
  1. HP 15-ac142dx Screen Replacement, Screen: 1 단계, 이미지 1/1
    • The first step you should take is to turn the laptop off.
    • Next you want to get the prying tool and wedge it into the seam of the screen and outer casing.
  2. HP 15-ac142dx Screen Replacement: 2 단계, 이미지 1/2 HP 15-ac142dx Screen Replacement: 2 단계, 이미지 2/2
    • Once it is wedged in on one of the upper corners you want to gently lift and slide the tool down the sides and top of the seam until the frame pops off.
    • Continue moving the tool down, while wedged, to release the grasp. You will be left with just the screen in the casing.
    • While prying off make sure you have a good grasp on the computer. You will know it is coming off due to the audible clicks
  3. HP 15-ac142dx Screen Replacement: 3 단계, 이미지 1/2 HP 15-ac142dx Screen Replacement: 3 단계, 이미지 2/2
    • Next, you will want to unscrew the Phillips PM2.0×5.2 screws at the top of the screen with the #0 bit, this will allow the screen to pop off easily.
    • Once all the screws are removed, gently remove the screen from the outer casing.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Nicole Mathieu
회원 가입일: 03/19/18
620 평판
안내서 5개 작성하였습니다
UMass Dartmouth, Team S2-G4, Bernier Spring 2018 UMass Dartmouth, Team S2-G4, Bernier Spring 2018 회원
UMASSD-BERNIER-S18S2G4
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 5
전체 시간: 593
