주요 콘텐츠로 건너뛰기
HP 15-af013cl AC Adapter Replacement
필요한 것
  1. HP 15-af013cl AC Adapter Replacement, Battery: 1 단계, 이미지 1/1
    • Start off by flipping the laptop on its back.
  2. HP 15-af013cl AC Adapter Replacement: 2 단계, 이미지 1/3 HP 15-af013cl AC Adapter Replacement: 2 단계, 이미지 2/3 HP 15-af013cl AC Adapter Replacement: 2 단계, 이미지 3/3
    • Push the two spring-loaded tabs inward.
    • Once unlatched, pull the battery out of its compartment.
  3. HP 15-af013cl AC Adapter Replacement, Motherboard: 3 단계, 이미지 1/1
    • Using the Phillips P0 screwdriver, remove the nine 2.5mm x 6.5mm screws from the bottom of the laptop.
    • Remove the additional two 2.0mm × 1.5mm Phillips screws located in the battery compartment.
  4. HP 15-af013cl AC Adapter Replacement: 4 단계, 이미지 1/2 HP 15-af013cl AC Adapter Replacement: 4 단계, 이미지 2/2
    • Remove the optical disk drive from the side of the laptop.
  5. HP 15-af013cl AC Adapter Replacement: 5 단계, 이미지 1/1
    • Lift off the bottom cover, exposing the motherboard and other components underneath.
  6. HP 15-af013cl AC Adapter Replacement: 6 단계, 이미지 1/2 HP 15-af013cl AC Adapter Replacement: 6 단계, 이미지 2/2
    • Begin by removing the 3 Phillips M2.0mm × 10.0mm screws of the processor fan.
    • Disconnect the fan connector from the motherboard.
  7. HP 15-af013cl AC Adapter Replacement: 7 단계, 이미지 1/1
    • Remove the five Phillips 2.5mm × 6 .5mm screws using the Phillips P0 screwdriver.
  8. HP 15-af013cl AC Adapter Replacement: 8 단계, 이미지 1/3 HP 15-af013cl AC Adapter Replacement: 8 단계, 이미지 2/3 HP 15-af013cl AC Adapter Replacement: 8 단계, 이미지 3/3
    • Disconnect the ribbon cables for the keyboard, display, trackpad and the various system components.
    • Remove the Wi-Fi card and cables.
  9. HP 15-af013cl AC Adapter Replacement: 9 단계, 이미지 1/1
    • Carefully lift out the motherboard from the laptop.
  10. HP 15-af013cl AC Adapter Replacement, AC Adapter: 10 단계, 이미지 1/1
    • Remove the 2 M2.0mm × 5.0mm Phillips screws located on the metal screen hinge closest to where the processor fan was.
  11. HP 15-af013cl AC Adapter Replacement: 11 단계, 이미지 1/3 HP 15-af013cl AC Adapter Replacement: 11 단계, 이미지 2/3 HP 15-af013cl AC Adapter Replacement: 11 단계, 이미지 3/3
    • Lift off the metal hinge from the laptop body.
    • Gently pull up on the cable leading to the charging port.
결론
Stephen Perreira
회원 가입일: 09/27/17
787 평판
안내서 6개 작성하였습니다
Cal Poly, Team S8-G6, Banghart Fall 2017 Cal Poly, Team S8-G6, Banghart Fall 2017 회원
CPSU-BANGHART-F17S8G6
5 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 5
전체 시간: 711
