주요 콘텐츠로 건너뛰기
HP 15-af013cl Front Facing Camera Replacement
필요한 것
  1. HP 15-af013cl Front Facing Camera Replacement, Battery: 1 단계, 이미지 1/1
    • Start off by flipping the laptop on its back.
  2. HP 15-af013cl Front Facing Camera Replacement: 2 단계, 이미지 1/3 HP 15-af013cl Front Facing Camera Replacement: 2 단계, 이미지 2/3 HP 15-af013cl Front Facing Camera Replacement: 2 단계, 이미지 3/3
    • Push the two spring-loaded tabs inward.
    • Once unlatched, pull the battery out of its compartment.
  3. HP 15-af013cl Front Facing Camera Replacement, Screen: 3 단계, 이미지 1/1
    • Flip the laptop over and have it open as you normally would.
  4. HP 15-af013cl Front Facing Camera Replacement: 4 단계, 이미지 1/3 HP 15-af013cl Front Facing Camera Replacement: 4 단계, 이미지 2/3 HP 15-af013cl Front Facing Camera Replacement: 4 단계, 이미지 3/3
    • Using a pry tool, unclip the entire outer plastic cover from the front of the screen.
    • Gently remove the front plastic cover.
  5. HP 15-af013cl Front Facing Camera Replacement: 5 단계, 이미지 1/1
    • Remove the two 2.5mm × 3.0mm Phillips screws from each corner of the display.
  6. HP 15-af013cl Front Facing Camera Replacement: 6 단계, 이미지 1/2 HP 15-af013cl Front Facing Camera Replacement: 6 단계, 이미지 2/2
    • Carefully lift the display out of the laptop shell and flip it on its front.
    • Disconnect the single cable from the back of the display.
  7. HP 15-af013cl Front Facing Camera Replacement, Front Facing Camera: 7 단계, 이미지 1/2 HP 15-af013cl Front Facing Camera Replacement, Front Facing Camera: 7 단계, 이미지 2/2
    • The front camera is held in by light adhesive. Pry gently on the back of the camera in order to remove it.
    • Remove the cable from under the metal foil.
  8. HP 15-af013cl Front Facing Camera Replacement: 8 단계, 이미지 1/1
    • Flip the laptop back over.
    • Using the Phillips P0 screwdriver, remove the 9 M2.5mm x 6.5mm screws from the bottom of the laptop.
    • Remove the additional 2 M2.0mm × 1.5mm Phillips screws located in the battery compartment.
  9. HP 15-af013cl Front Facing Camera Replacement: 9 단계, 이미지 1/2 HP 15-af013cl Front Facing Camera Replacement: 9 단계, 이미지 2/2
    • Remove the optical disk drive from the side of the laptop.
  10. HP 15-af013cl Front Facing Camera Replacement: 10 단계, 이미지 1/1
    • Lift off the bottom cover, exposing the motherboard and other components underneath.
  11. HP 15-af013cl Front Facing Camera Replacement: 11 단계, 이미지 1/1
    • Disconnect the display ribbon cable from the motherboard.
결론
Stephen Perreira
회원 가입일: 09/27/17
787 평판
안내서 6개 작성하였습니다
Cal Poly, Team S8-G6, Banghart Fall 2017 Cal Poly, Team S8-G6, Banghart Fall 2017 회원
CPSU-BANGHART-F17S8G6
5 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 5
전체 시간: 409
