주요 콘텐츠로 건너뛰기
HP 15-af013cl Hard Drive Replacement
필요한 것
  1. HP 15-af013cl Hard Drive Replacement, Battery: 1 단계, 이미지 1/1
    • Start off by flipping the laptop on its back.
  2. HP 15-af013cl Hard Drive Replacement: 2 단계, 이미지 1/3 HP 15-af013cl Hard Drive Replacement: 2 단계, 이미지 2/3 HP 15-af013cl Hard Drive Replacement: 2 단계, 이미지 3/3
    • Push the two spring-loaded tabs inward.
    • Once unlatched, pull the battery out of its compartment.
  3. HP 15-af013cl Hard Drive Replacement, Hard Drive: 3 단계, 이미지 1/1
    • Using the Phillips P0 screwdriver, remove the 9 M2.5mm x 6.5mm screws from the bottom of the laptop.
    • Remove the additional 2 M2.0mm × 1.5mm Phillips screws located in the battery compartment.
  4. HP 15-af013cl Hard Drive Replacement: 4 단계, 이미지 1/2 HP 15-af013cl Hard Drive Replacement: 4 단계, 이미지 2/2
    • Remove the optical disk drive from the side of the laptop.
  5. HP 15-af013cl Hard Drive Replacement: 5 단계, 이미지 1/2 HP 15-af013cl Hard Drive Replacement: 5 단계, 이미지 2/2
    • Lift off the bottom cover, exposing the motherboard and other components underneath.
    • Unscrew the four Phillips 3.0mm x 3.5mm screws on the hard drive bracket using the PH0 screwdriver.
  6. HP 15-af013cl Hard Drive Replacement: 6 단계, 이미지 1/2 HP 15-af013cl Hard Drive Replacement: 6 단계, 이미지 2/2
    • Gently lift the hard drive from its position on the inside of the laptop.
    • Disconnect the ribbon cable from the hard drive.
결론
Stephen Perreira
회원 가입일: 09/27/17
787 평판
안내서 6개 작성하였습니다
Cal Poly, Team S8-G6, Banghart Fall 2017 Cal Poly, Team S8-G6, Banghart Fall 2017 회원
CPSU-BANGHART-F17S8G6
5 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 5
전체 시간: 1,249
