주요 콘텐츠로 건너뛰기
HP 15-af013cl Motherboard Replacement
필요한 것
  1. HP 15-af013cl Motherboard Replacement, Battery: 1 단계, 이미지 1/1
    • Start off by flipping the laptop on its back.
  2. HP 15-af013cl Motherboard Replacement: 2 단계, 이미지 1/3 HP 15-af013cl Motherboard Replacement: 2 단계, 이미지 2/3 HP 15-af013cl Motherboard Replacement: 2 단계, 이미지 3/3
    • Push the two spring-loaded tabs inward.
    • Once unlatched, pull the battery out of its compartment.
  3. HP 15-af013cl Motherboard Replacement, Motherboard: 3 단계, 이미지 1/1
    • Using the Phillips P0 screwdriver, remove the nine 2.5mm x 6.5mm screws from the bottom of the laptop.
    • Remove the additional two 2.0mm × 1.5mm Phillips screws located in the battery compartment.
  4. HP 15-af013cl Motherboard Replacement: 4 단계, 이미지 1/2 HP 15-af013cl Motherboard Replacement: 4 단계, 이미지 2/2
    • Remove the optical disk drive from the side of the laptop.
  5. HP 15-af013cl Motherboard Replacement: 5 단계, 이미지 1/1
    • Lift off the bottom cover, exposing the motherboard and other components underneath.
  6. HP 15-af013cl Motherboard Replacement: 6 단계, 이미지 1/2 HP 15-af013cl Motherboard Replacement: 6 단계, 이미지 2/2
    • Begin by removing the 3 Phillips M2.0mm × 10.0mm screws of the processor fan.
    • Disconnect the fan connector from the motherboard.
  7. HP 15-af013cl Motherboard Replacement: 7 단계, 이미지 1/1
    • Remove the five Phillips 2.5mm × 6 .5mm screws using the Phillips P0 screwdriver.
  8. HP 15-af013cl Motherboard Replacement: 8 단계, 이미지 1/3 HP 15-af013cl Motherboard Replacement: 8 단계, 이미지 2/3 HP 15-af013cl Motherboard Replacement: 8 단계, 이미지 3/3
    • Disconnect the ribbon cables for the keyboard, display, trackpad and the various system components.
    • Remove the Wi-Fi card and cables.
  9. HP 15-af013cl Motherboard Replacement: 9 단계, 이미지 1/1
    • Carefully lift out the motherboard from the laptop.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Stephen Perreira
회원 가입일: 09/27/17
787 평판
안내서 6개 작성하였습니다
Cal Poly, Team S8-G6, Banghart Fall 2017 Cal Poly, Team S8-G6, Banghart Fall 2017 회원
CPSU-BANGHART-F17S8G6
5 회원들
안내서 6개 작성하였습니다
댓글 한 개
i need motherboard hp model:15-bs127ne
elbetel ashenafi - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 12
전체 시간: 2,017
