주요 콘텐츠로 건너뛰기
HP 15-af123cl Hard Drive Replacement
필요한 것
  1. HP 15-af123cl Hard Drive Replacement, Battery: 1 단계, 이미지 1/2 HP 15-af123cl Hard Drive Replacement, Battery: 1 단계, 이미지 2/2
    • Push the slider with a lock symbol to the right to unlock the battery.
  2. HP 15-af123cl Hard Drive Replacement: 2 단계, 이미지 1/1
    • Push the slider with a battery symbol to the left to push the battery out slightly.
    • Pull the battery out fully now that it is released.
  3. HP 15-af123cl Hard Drive Replacement, Back Cover: 3 단계, 이미지 1/1
    • Remove the twelve screws from the bottom of the laptop using a Phillips #00 screwdriver.
  4. HP 15-af123cl Hard Drive Replacement: 4 단계, 이미지 1/3 HP 15-af123cl Hard Drive Replacement: 4 단계, 이미지 2/3 HP 15-af123cl Hard Drive Replacement: 4 단계, 이미지 3/3
    • Turn the laptop over and open the lid.
    • Use an opening tool to pry the bottom cover from the body of the laptop.
  5. HP 15-af123cl Hard Drive Replacement: 5 단계, 이미지 1/2 HP 15-af123cl Hard Drive Replacement: 5 단계, 이미지 2/2
    • Close and turn over the laptop again.
    • Pull the back cover up to remove it from the laptop.
  6. HP 15-af123cl Hard Drive Replacement, Hard Drive: 6 단계, 이미지 1/2 HP 15-af123cl Hard Drive Replacement, Hard Drive: 6 단계, 이미지 2/2
    • Unclip the cable connected to the drive using an opening tool.
  7. HP 15-af123cl Hard Drive Replacement: 7 단계, 이미지 1/3 HP 15-af123cl Hard Drive Replacement: 7 단계, 이미지 2/3 HP 15-af123cl Hard Drive Replacement: 7 단계, 이미지 3/3
    • Remove the screws from the brackets around the hard drive using a Phillips #00 screwdriver.
  8. HP 15-af123cl Hard Drive Replacement: 8 단계, 이미지 1/1
    • Remove the brackets from around the hard drive.
    • Remove the hard drive from the laptop.
결론
Victoria Santos
회원 가입일: 10/25/21
698 평판
안내서 6개 작성하였습니다
UMass Dartmouth, Team 2-5, Sinclaire Fall 2021 UMass Dartmouth, Team 2-5, Sinclaire Fall 2021 회원
UMASSD-SINCLAIRE-F21S2G5
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 8
전체 시간: 426
