소개
This guide will show you how to replace the SATA drive on your HP 15-af123cl. if your computer isn’t booting, at all, or if you computer shows you have corrupted memory in your drive it is time to replace your sata drive.
make sure you are using ESD tools, and a ESD-band you do not want to be damaging any of your components static electricity.
make sure to back-up all the data on your drive as you are replacing it, if you do not, you will lose anything not backup to a cloud or other form of storage
make sure to turn off the computer completely and disconnect the charging cable or any other external power source.
필요한 것
Remove the twelve screws from the bottom of the laptop using a Phillips #00 screwdriver.
