주요 콘텐츠로 건너뛰기
HP 15-ay011nr Fan Replacement
필요한 것
  1. HP 15-ay011nr Fan Replacement, Battery: 1 단계, 이미지 1/1
    • Slide the two battery lock latches on the back of the device to the “unlock” position.
  2. HP 15-ay011nr Fan Replacement: 2 단계, 이미지 1/1
    • Lift the battery upward to remove it from the device.
  3. HP 15-ay011nr Fan Replacement, Back Panel: 3 단계, 이미지 1/1
    • Using the PH1 phillips-head screwdriver, remove all the 5/16 in. screws from the back of the device.
    • There should be 10 in total, be sure to keep them together!
  4. HP 15-ay011nr Fan Replacement: 4 단계, 이미지 1/1
    • Locate the optical disc drive and remove it from the device by sliding it straight of the device.
  5. HP 15-ay011nr Fan Replacement: 5 단계, 이미지 1/2 HP 15-ay011nr Fan Replacement: 5 단계, 이미지 2/2
    • Covering the hinges of the device are rubber bumpers secured to the device using adhesive. Remove them carefully.
    • Place the adhesive side up as you will need to place them back after your replacement is complete.
  6. HP 15-ay011nr Fan Replacement: 6 단계, 이미지 1/2 HP 15-ay011nr Fan Replacement: 6 단계, 이미지 2/2
    • In the same spot you’ve just removed the bumpers from, you will find two 5/16 in. screws. Using the same Phillips-head screwdriver used in step 2, remove the screws
    • Be sure to keep the screws together!
  7. HP 15-ay011nr Fan Replacement: 7 단계, 이미지 1/1
    • Carefully remove the back panel from the device.
    • If you are unable to do this with your hands, you can use a thin prying tool of your choice to make it easier!
  8. HP 15-ay011nr Fan Replacement, Fan: 8 단계, 이미지 1/2 HP 15-ay011nr Fan Replacement, Fan: 8 단계, 이미지 2/2
    • There are two 5/16 in. screws adjacent from each other that secure the fan to the device. Use the PH1 phillips-head screwdriver to remove them.
    • Be sure to keep them together!
  9. HP 15-ay011nr Fan Replacement: 9 단계, 이미지 1/2 HP 15-ay011nr Fan Replacement: 9 단계, 이미지 2/2
    • Lift the clear plastic strip holding down the fan and lift the fan out of place.
  10. HP 15-ay011nr Fan Replacement: 10 단계, 이미지 1/2 HP 15-ay011nr Fan Replacement: 10 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Use your fingers or tweezers to pinch both sides of the connector and remove the fan from the device.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Daymon Brisco
회원 가입일: 09/25/17
288 평판
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 10
전체 시간: 1,463
