주요 콘텐츠로 건너뛰기
HP 15-ay014dx Battery Replacement
  1. HP 15-ay014dx Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Disconnect device from power source and power down.
  2. HP 15-ay014dx Battery Replacement: 2 단계, 이미지 1/1
    • With the device turned upside down, use your index fingers to push the battery latches in towards each other.
  3. HP 15-ay014dx Battery Replacement: 3 단계, 이미지 1/1
    • The latch on your left will stay at the inward position, while the latch on the right will slide back out.
    • Gently grasp the battery and pull it back away from the device and yourself.
결론
To reassemble your device, follow these steps in reverse order.
다른 2명이 해당 안내서를 완성하였습니다.
Nathan Rapalus
회원 가입일: 09/21/17
137 평판
안내서 1개 작성함
Washington State, Team S1-G4, Phelps-Hillen Fall 2017 Washington State, Team S1-G4, Phelps-Hillen Fall 2017 회원
WSU-PHELPS-HILLEN-F17S1G4
6 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 6
전체 시간: 796
