소개
This guide will provide simple, easy to follow instructions for replacing the Hard Drive Disk for HP-15ay014dx
필요한 것
Close the laptop and lay it down with the bottom facing up.
Using a size #00 Phillips screw drive remove the screw holding in the optical drive.
Remove the highlighted screws holding the body of the laptop together with a size #00 Phillips screwdriver.
다른 6명이 해당 안내서를 완성하였습니다.
