주요 콘텐츠로 건너뛰기
HP 15-ay014dx Motherboard Replacement
필요한 것
  1. HP 15-ay014dx Motherboard Replacement, Battery: 1 단계, 이미지 1/1
    • Disconnect device from power source and power down.
  2. HP 15-ay014dx Motherboard Replacement: 2 단계, 이미지 1/1
    • With the device turned upside down, use your index fingers to push the battery latches in towards each other.
  3. HP 15-ay014dx Motherboard Replacement: 3 단계, 이미지 1/1
    • The latch on your left will stay at the inward position, while the latch on the right will slide back out.
    • Gently grasp the battery and pull it back away from the device and yourself.
  4. HP 15-ay014dx Motherboard Replacement, Optical Drive: 4 단계, 이미지 1/1
    • Close the laptop and lay it down with the bottom facing up.
    • Using a size #00 Phillips screw drive remove the screw holding in the optical drive.
  5. HP 15-ay014dx Motherboard Replacement: 5 단계, 이미지 1/1
    • Grip the optical drive and gently pull it out.
  6. HP 15-ay014dx Motherboard Replacement, RAM: 6 단계, 이미지 1/1
    • Remove the 11 screws holding the body of the laptop together with a size #00 Phillips screwdriver.
  7. HP 15-ay014dx Motherboard Replacement: 7 단계, 이미지 1/2 HP 15-ay014dx Motherboard Replacement: 7 단계, 이미지 2/2
    • Use the spudger to press the tabs in the back of the computer. Carefully remove the back of the laptop by prying around the sides using the plastic opening tool.
  8. HP 15-ay014dx Motherboard Replacement: 8 단계, 이미지 1/2 HP 15-ay014dx Motherboard Replacement: 8 단계, 이미지 2/2
    • Undo the clips holding the RAM in place using the plastic opening tool.
  9. HP 15-ay014dx Motherboard Replacement: 9 단계, 이미지 1/1
    • Carefully pull out the RAM from the motherboard.
  10. HP 15-ay014dx Motherboard Replacement, Hard Drive Disk: 10 단계, 이미지 1/2 HP 15-ay014dx Motherboard Replacement, Hard Drive Disk: 10 단계, 이미지 2/2
    • Remove the highlighted screws holding the body of the laptop together with a size #00 Phillips screwdriver.
  11. HP 15-ay014dx Motherboard Replacement: 11 단계, 이미지 1/3 HP 15-ay014dx Motherboard Replacement: 11 단계, 이미지 2/3 HP 15-ay014dx Motherboard Replacement: 11 단계, 이미지 3/3
    • Using the spudger, push in the tabs in the back that hold the body together. Carefully pry the body apart by working the spudger around the body.
    • Pull the back cover off.
  12. HP 15-ay014dx Motherboard Replacement: 12 단계, 이미지 1/3 HP 15-ay014dx Motherboard Replacement: 12 단계, 이미지 2/3 HP 15-ay014dx Motherboard Replacement: 12 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Pry up on the clamp holding the SATA power ribbon using the plastic opening tool.
    • Pull out the SATA power ribbon using the tweezers.
  13. HP 15-ay014dx Motherboard Replacement: 13 단계, 이미지 1/2 HP 15-ay014dx Motherboard Replacement: 13 단계, 이미지 2/2
    • Remove the highlighted screws holding the hard drive to the body using the Philips #00 screwdriver.
    • Remove the hard drive.
  14. HP 15-ay014dx Motherboard Replacement: 14 단계, 이미지 1/1
    • Remove the 4 screws holding the hard drive to the hard drive cage using the Philips #00 screwdriver.
  15. HP 15-ay014dx Motherboard Replacement, Wireless Card: 15 단계, 이미지 1/1
  16. HP 15-ay014dx Motherboard Replacement: 16 단계, 이미지 1/2 HP 15-ay014dx Motherboard Replacement: 16 단계, 이미지 2/2
  17. HP 15-ay014dx Motherboard Replacement: 17 단계, 이미지 1/2 HP 15-ay014dx Motherboard Replacement: 17 단계, 이미지 2/2
    • Using the spudger, carefully pry the wire connecting the wireless card to the motherboard off of it.
  18. HP 15-ay014dx Motherboard Replacement: 18 단계, 이미지 1/1
    • Using the size #00 Phillips screwdriver remove the single screw holding it in place.
  19. HP 15-ay014dx Motherboard Replacement: 19 단계, 이미지 1/1
    • carefully pull the card of its slot.
  20. HP 15-ay014dx Motherboard Replacement, Motherboard: 20 단계, 이미지 1/3 HP 15-ay014dx Motherboard Replacement, Motherboard: 20 단계, 이미지 2/3 HP 15-ay014dx Motherboard Replacement, Motherboard: 20 단계, 이미지 3/3
    • Disconnect all ribbon connectors by flipping up the black tabs and gently pulling them out.
    • Disconnect​ ​the​ ​speakers​ ​by​ ​gently ​pulling​​ ​the​ ​connector ​out.
    • Disconnect​ ​the​ ​Fan​ ​by​ ​gently ​pulling​​ ​the​ ​connector​ ​out.
    • Disconnect the power by gently pulling the connectors out.
  21. HP 15-ay014dx Motherboard Replacement: 21 단계, 이미지 1/1
    • Unscrew the five screws securing the motherboards.
  22. HP 15-ay014dx Motherboard Replacement: 22 단계, 이미지 1/1
    • Gently lift the motherboard up and out of the casing.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Drake Scoville
회원 가입일: 09/21/17
533 평판
안내서 4개 작성하였습니다
Washington State, Team S1-G4, Phelps-Hillen Fall 2017 Washington State, Team S1-G4, Phelps-Hillen Fall 2017 회원
WSU-PHELPS-HILLEN-F17S1G4
6 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 5
전체 시간: 1,628
