주요 콘텐츠로 건너뛰기
HP 15-ay014dx Optical Drive Replacement
필요한 것
  1. HP 15-ay014dx Optical Drive Replacement, Battery: 1 단계, 이미지 1/1
    • Disconnect device from power source and power down.
  2. HP 15-ay014dx Optical Drive Replacement: 2 단계, 이미지 1/1
    • With the device turned upside down, use your index fingers to push the battery latches in towards each other.
  3. HP 15-ay014dx Optical Drive Replacement: 3 단계, 이미지 1/1
    • The latch on your left will stay at the inward position, while the latch on the right will slide back out.
    • Gently grasp the battery and pull it back away from the device and yourself.
  4. HP 15-ay014dx Optical Drive Replacement, Optical Drive: 4 단계, 이미지 1/1
    • Close the laptop and lay it down with the bottom facing up.
    • Using a size #00 Phillips screw drive remove the screw holding in the optical drive.
  5. HP 15-ay014dx Optical Drive Replacement: 5 단계, 이미지 1/1
    • Grip the optical drive and gently pull it out.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Colton King
회원 가입일: 09/21/17
227 평판
안내서 1개 작성함
Washington State, Team S1-G4, Phelps-Hillen Fall 2017 Washington State, Team S1-G4, Phelps-Hillen Fall 2017 회원
WSU-PHELPS-HILLEN-F17S1G4
6 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 7
전체 시간: 282
