주요 콘텐츠로 건너뛰기
HP 15-ay014dx Wireless Card Replacement
필요한 것
  1. HP 15-ay014dx Wireless Card Replacement, Battery: 1 단계, 이미지 1/1
    • Disconnect device from power source and power down.
  2. HP 15-ay014dx Wireless Card Replacement: 2 단계, 이미지 1/1
    • With the device turned upside down, use your index fingers to push the battery latches in towards each other.
  3. HP 15-ay014dx Wireless Card Replacement: 3 단계, 이미지 1/1
    • The latch on your left will stay at the inward position, while the latch on the right will slide back out.
    • Gently grasp the battery and pull it back away from the device and yourself.
  4. HP 15-ay014dx Wireless Card Replacement, Optical Drive: 4 단계, 이미지 1/1
    • Close the laptop and lay it down with the bottom facing up.
    • Using a size #00 Phillips screw drive remove the screw holding in the optical drive.
  5. HP 15-ay014dx Wireless Card Replacement: 5 단계, 이미지 1/1
    • Grip the optical drive and gently pull it out.
  6. HP 15-ay014dx Wireless Card Replacement, Wireless Card: 6 단계, 이미지 1/1
    • Remove the 11 screws holding the body of the laptop together with a size #00 Phillips screwdriver.
  7. HP 15-ay014dx Wireless Card Replacement: 7 단계, 이미지 1/2 HP 15-ay014dx Wireless Card Replacement: 7 단계, 이미지 2/2
    • Using the spudger, push in the tabs in the back that hold the body together. Carefully pry the body apart by working the spudger around the body.
  8. HP 15-ay014dx Wireless Card Replacement: 8 단계, 이미지 1/2 HP 15-ay014dx Wireless Card Replacement: 8 단계, 이미지 2/2
    • Using the spudger, carefully pry the wire connecting the wireless card to the motherboard off of it.
  9. HP 15-ay014dx Wireless Card Replacement: 9 단계, 이미지 1/1
    • Using the size #00 Phillips screwdriver remove the single screw holding it in place.
  10. HP 15-ay014dx Wireless Card Replacement: 10 단계, 이미지 1/1
    • carefully pull the card of its slot.
결론
Drake Scoville
회원 가입일: 09/21/17
533 평판
안내서 4개 작성하였습니다
Washington State, Team S1-G4, Phelps-Hillen Fall 2017 Washington State, Team S1-G4, Phelps-Hillen Fall 2017 회원
WSU-PHELPS-HILLEN-F17S1G4
6 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 4
전체 시간: 414
