주요 콘텐츠로 건너뛰기
HP 15-ay091ms Optical Disk Drive Replacement
필요한 것
  1. HP 15-ay091ms Optical Disk Drive Replacement, Battery: 1 단계, 이미지 1/2 HP 15-ay091ms Optical Disk Drive Replacement, Battery: 1 단계, 이미지 2/2
    • Ensure the device is powered off and is disconnected from any AC power supply.
    • Push the latches on either side of the battery down and outward.
    • This unlatches the battery allowing for easy removal.
    • Remove the battery.
  2. HP 15-ay091ms Optical Disk Drive Replacement, Back Panel: 2 단계, 이미지 1/3 HP 15-ay091ms Optical Disk Drive Replacement, Back Panel: 2 단계, 이미지 2/3 HP 15-ay091ms Optical Disk Drive Replacement, Back Panel: 2 단계, 이미지 3/3
    • Remove the screws from the bottom panel using a JIS #0 screwdriver.
    • Use the iFixit opening pick to lift the back cover from the device.
    • It is helpful to get an opening in one spot of the back cover and carry that opening around the device.
  3. HP 15-ay091ms Optical Disk Drive Replacement, Optical Disk Drive: 3 단계, 이미지 1/3 HP 15-ay091ms Optical Disk Drive Replacement, Optical Disk Drive: 3 단계, 이미지 2/3 HP 15-ay091ms Optical Disk Drive Replacement, Optical Disk Drive: 3 단계, 이미지 3/3
    • Remove the screws holding the optical drive in place using a JIS #0 screwdriver.
    • Pull the optical disk drive out of its slot.
결론
Jossel Solis
회원 가입일: 09/07/23
173 평판
안내서 1개 작성함
Gateway, Team A-1, Gonzalez Fall 2023 Gateway, Team A-1, Gonzalez Fall 2023 회원
GCC-GONZALEZ-F23SAG1
4 회원들
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 75
