주요 콘텐츠로 건너뛰기
HP 15-ba0709dx Back Cover Replacement
필요한 것
  1. HP 15-ba0709dx Back Cover Replacement, Battery: 1 단계, 이미지 1/1
    • Flip the device over and locate the battery compartment.
    • Slide the battery release latch on the left and right side until the battery is detached from its slot.
    • A noticeable pop will be heard when the battery is fully released.
  2. HP 15-ba0709dx Back Cover Replacement: 2 단계, 이미지 1/1
    • Pull the battery out of its slot.
    • Be careful not to damage any of the connectors in the process.
  3. HP 15-ba0709dx Back Cover Replacement, Back Cover: 3 단계, 이미지 1/1
    • Place the laptop on a clean, flat surface with the bottom side facing up.
  4. HP 15-ba0709dx Back Cover Replacement: 4 단계, 이미지 1/1
    • Using a Phillips Head Screwdriver, remove the screws anchoring the bottom casing.
    • Note: Make sure to keep track of the screws once they have been removed.
  5. HP 15-ba0709dx Back Cover Replacement: 5 단계, 이미지 1/1
    • Locate the screws about 1 inch from the battery release tabs and use a Phillips Head Screwdriver to remove these screws.
    • Note:Place these newly removed screws with the ones removed in Step 2.
  6. HP 15-ba0709dx Back Cover Replacement: 6 단계, 이미지 1/2 HP 15-ba0709dx Back Cover Replacement: 6 단계, 이미지 2/2
    • Locate the rubber friction pads on the top corners of the laptop. Pry the pads from the laptop and place them off to the side
    • Removing the friction pads will reveal two more anchoring screws.
    • Note: The adhesive keeping the pads on the laptop will weaken once doing this, but it is necessary to removing the bottom cover of the laptop.
  7. HP 15-ba0709dx Back Cover Replacement: 7 단계, 이미지 1/1
    • Remove disc reader.
    • Note: If all screws are removed it should slide out easily.
  8. HP 15-ba0709dx Back Cover Replacement: 8 단계, 이미지 1/2 HP 15-ba0709dx Back Cover Replacement: 8 단계, 이미지 2/2
    • Use a plastic prod to pry the back cover off the laptop.
    • Be careful not to damage the laptop while prying.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Lydia Brown
회원 가입일: 03/20/17
369 평판
안내서 2개 작성하였습니다
Texas Tech, Team S13-G3, Bennett Spring 2017 Texas Tech, Team S13-G3, Bennett Spring 2017 회원
TTU-BENNETT-S17S13G3
5 회원들
안내서 5개 작성하였습니다
댓글 2개
Make sure to use a very thin shim, but strong enough to pry.
spotty118 - 답글
thanks- also worked for 15-ba053nr
Renee Brandt - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 11
전체 시간: 1,919
