소개
Follow this guide to replace the hard drive on HP 15-ba0709dx laptop. This repair may be needed if your computer is showing the symptoms such as freezing, slowing down, or corrupting files.
필요한 것
Flip the device over and locate the battery compartment.
Slide the battery release latch on the left and right side until the battery is detached from its slot.
A noticeable pop will be heard when the battery is fully released.
Locate the square, blue hard drive
Unscrew the two screws holding it in place using a Philips screwdriver head, PH1. The screws will be 8 mm long with a 4 mm width head.
다른 5명이 해당 안내서를 완성하였습니다.
