주요 콘텐츠로 건너뛰기
HP 15-bs051od Motherboard Replacement
필요한 것
  1. HP 15-bs051od Motherboard Replacement, RAM: 1 단계, 이미지 1/1
    • Start with the laptop face down.
    • Remove the eight 6 mm Phillips head screws securing the lower case.
  2. HP 15-bs051od Motherboard Replacement: 2 단계, 이미지 1/2 HP 15-bs051od Motherboard Replacement: 2 단계, 이미지 2/2
    • Use the opening tool to pry the lower case away from the body of the laptop.
    • Remove the lower case.
  3. HP 15-bs051od Motherboard Replacement: 3 단계, 이미지 1/3 HP 15-bs051od Motherboard Replacement: 3 단계, 이미지 2/3 HP 15-bs051od Motherboard Replacement: 3 단계, 이미지 3/3
    • Pull the RAM-retaining arms away from the RAM chip.
    • The RAM chip should slightly "pop" up from it's socket.
  4. HP 15-bs051od Motherboard Replacement: 4 단계, 이미지 1/2 HP 15-bs051od Motherboard Replacement: 4 단계, 이미지 2/2
    • Pull the RAM chip out of its socket.
    • Our device does not specifically have a second RAM chip, but make sure to remove the second RAM chip below the first RAM chip.
    • Repeat this process for the second RAM chip.
  5. HP 15-bs051od Motherboard Replacement, Motherboard: 5 단계, 이미지 1/3 HP 15-bs051od Motherboard Replacement, Motherboard: 5 단계, 이미지 2/3 HP 15-bs051od Motherboard Replacement, Motherboard: 5 단계, 이미지 3/3
    • Remove the four (4 mm) Phillips screws on the heatsink.
    • Remove the exhaust by carefully lifting it up.
  6. HP 15-bs051od Motherboard Replacement: 6 단계, 이미지 1/1
    • Disconnect the connecting cable of the fan and remove the fan.
  7. HP 15-bs051od Motherboard Replacement: 7 단계, 이미지 1/2 HP 15-bs051od Motherboard Replacement: 7 단계, 이미지 2/2
    • Pull the red, white, black, and blue cable directly out of its port.
  8. HP 15-bs051od Motherboard Replacement: 8 단계, 이미지 1/1
    • Slide the left speaker out.
  9. HP 15-bs051od Motherboard Replacement: 9 단계, 이미지 1/1
    • Pull the black and red cable connecting both speakers out of its secure fastening.
  10. HP 15-bs051od Motherboard Replacement: 10 단계, 이미지 1/1
    • Pull the right speaker out by sliding from left to right.
  11. HP 15-bs051od Motherboard Replacement: 11 단계, 이미지 1/2 HP 15-bs051od Motherboard Replacement: 11 단계, 이미지 2/2
    • Locate the motherboard.
    • The motherboard is the biggest blue-colored surface located inside the computer.
    • Locate the six ribbon cables.
  12. HP 15-bs051od Motherboard Replacement: 12 단계, 이미지 1/2 HP 15-bs051od Motherboard Replacement: 12 단계, 이미지 2/2
    • Flip up the ZIF lock bars that keep the six ribbon cables in place.
    • Slide the rest of the ribbon cables out of their fastenings.
  13. HP 15-bs051od Motherboard Replacement: 13 단계, 이미지 1/2 HP 15-bs051od Motherboard Replacement: 13 단계, 이미지 2/2
    • Remove the four (4 mm) Phillips screws securing the motherboard.
  14. HP 15-bs051od Motherboard Replacement: 14 단계, 이미지 1/2 HP 15-bs051od Motherboard Replacement: 14 단계, 이미지 2/2
    • Remove the single (4 mm) Phillips screw on the Wi-Fi card.
    • Slide the Wi-Fi card out of its port.
  15. HP 15-bs051od Motherboard Replacement: 15 단계, 이미지 1/2 HP 15-bs051od Motherboard Replacement: 15 단계, 이미지 2/2
    • Unfasten the connecting cable.
  16. HP 15-bs051od Motherboard Replacement: 16 단계, 이미지 1/2 HP 15-bs051od Motherboard Replacement: 16 단계, 이미지 2/2
    • Remove the display cable.
  17. HP 15-bs051od Motherboard Replacement: 17 단계, 이미지 1/1
    • Lift up the motherboard.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Jessica Walia
회원 가입일: 03/20/23
589 평판
안내서 4개 작성하였습니다
UMass Dartmouth, Team 6-1, Botvin Spring 2023 UMass Dartmouth, Team 6-1, Botvin Spring 2023 회원
UMASSD-BOTVIN-S23S6G1
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 14
전체 시간: 198
