주요 콘텐츠로 건너뛰기
HP 15-bs080wm Hard Drive Replacement
필요한 것
  1. HP 15-bs080wm Hard Drive Replacement, Hard Drive: 1 단계, 이미지 1/3 HP 15-bs080wm Hard Drive Replacement, Hard Drive: 1 단계, 이미지 2/3 HP 15-bs080wm Hard Drive Replacement, Hard Drive: 1 단계, 이미지 3/3
    • Power off the laptop.
    • Do not proceed until both power lights are off.
  2. HP 15-bs080wm Hard Drive Replacement: 2 단계, 이미지 1/3 HP 15-bs080wm Hard Drive Replacement: 2 단계, 이미지 2/3 HP 15-bs080wm Hard Drive Replacement: 2 단계, 이미지 3/3
    • Slide the battery lock to the unlock position..
    • Slide the battery release inwards to remove the battery.
  3. HP 15-bs080wm Hard Drive Replacement: 3 단계, 이미지 1/3 HP 15-bs080wm Hard Drive Replacement: 3 단계, 이미지 2/3 HP 15-bs080wm Hard Drive Replacement: 3 단계, 이미지 3/3
    • Use the plastic opening tool to remove the four rubber feet.
  4. HP 15-bs080wm Hard Drive Replacement: 4 단계, 이미지 1/3 HP 15-bs080wm Hard Drive Replacement: 4 단계, 이미지 2/3 HP 15-bs080wm Hard Drive Replacement: 4 단계, 이미지 3/3
    • Remove the center screw from the back of the laptop using a Phillips #000 screwdriver.
    • Remove the optical drive.
  5. HP 15-bs080wm Hard Drive Replacement: 5 단계, 이미지 1/3 HP 15-bs080wm Hard Drive Replacement: 5 단계, 이미지 2/3 HP 15-bs080wm Hard Drive Replacement: 5 단계, 이미지 3/3
    • Remove the nine screws from the back of the laptop using a Phillips #000 screwdriver.
  6. HP 15-bs080wm Hard Drive Replacement: 6 단계, 이미지 1/3 HP 15-bs080wm Hard Drive Replacement: 6 단계, 이미지 2/3 HP 15-bs080wm Hard Drive Replacement: 6 단계, 이미지 3/3
    • Use the plastic opening tool to wedge the back plate from the body of the laptop.
    • Flip the laptop over and remove the back plate.
    • Use the opening tool around the entire perimeter of the laptop's base.
  7. HP 15-bs080wm Hard Drive Replacement: 7 단계, 이미지 1/3 HP 15-bs080wm Hard Drive Replacement: 7 단계, 이미지 2/3 HP 15-bs080wm Hard Drive Replacement: 7 단계, 이미지 3/3
    • Remove the three screws from the hard drive bracket using a Phillips #000 screwdriver.
    • Remove the bracket.
    • Slide the hard drive the left to remove it from the socket.
결론
Landon Dickerson
회원 가입일: 02/22/22
195 평판
안내서 1개 작성함
University of North Texas, Team 1-4, Raign Spring 2022 University of North Texas, Team 1-4, Raign Spring 2022 회원
UNT-RAIGN-S22S1G4
2 회원들
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 14
전체 시간: 624
