주요 콘텐츠로 건너뛰기
HP 15-bw0xx Battery Replacement
필요한 것
  1. HP 15-bw0xx Battery Replacement, HP 15-bw0xx Battery: 1 단계, 이미지 1/3 HP 15-bw0xx Battery Replacement, HP 15-bw0xx Battery: 1 단계, 이미지 2/3 HP 15-bw0xx Battery Replacement, HP 15-bw0xx Battery: 1 단계, 이미지 3/3
    • First, start by identifying your laptop. Be sure it is specifically the "HP Laptop 15-bw0xx" model.
    • If you are unsure of the model, turn on your laptop. Then press and hold the "FN" key and the "ESC" key at the same time.
    • The model type is under the title "Product name."
  2. HP 15-bw0xx Battery Replacement: 2 단계, 이미지 1/1
    • Turn the closed laptop over onto its face, with the hinged side facing away from you.
    • Be sure to unplug your laptop and turn it off before continuing.
  3. HP 15-bw0xx Battery Replacement: 3 단계, 이미지 1/3 HP 15-bw0xx Battery Replacement: 3 단계, 이미지 2/3 HP 15-bw0xx Battery Replacement: 3 단계, 이미지 3/3
    • Place a finger on the top left slider, then push the black piece all the way to the right.
    • A finger grip to slide the hinge lock open lies to the left of a closed padlock symbol. This is how the battery is unlocked or locked in place.
  4. HP 15-bw0xx Battery Replacement: 4 단계, 이미지 1/3 HP 15-bw0xx Battery Replacement: 4 단계, 이미지 2/3 HP 15-bw0xx Battery Replacement: 4 단계, 이미지 3/3
    • Place a finger on the top right slider, then slide the black piece all the way to the left until it clicks out of place.
    • There will be three vertically parallel finger grips on the slider and a small 3/4 full battery symbol to the left of the slider. This slider is what detaches the battery from the laptop.
    • You may need to use a thumb or a little force to complete this step.
  5. HP 15-bw0xx Battery Replacement: 5 단계, 이미지 1/1
    • Remove the battery from the laptop.
  6. HP 15-bw0xx Battery Replacement: 6 단계, 이미지 1/3 HP 15-bw0xx Battery Replacement: 6 단계, 이미지 2/3 HP 15-bw0xx Battery Replacement: 6 단계, 이미지 3/3
    • Gently line the new battery up to the slot in which you removed the old battery from.
    • Press the battery into the slot until you hear it click into place.
  7. HP 15-bw0xx Battery Replacement: 7 단계, 이미지 1/3 HP 15-bw0xx Battery Replacement: 7 단계, 이미지 2/3 HP 15-bw0xx Battery Replacement: 7 단계, 이미지 3/3
    • Reverse Step #4 in order to safely lock the battery in place.
결론
After completing all of these steps, you will have successfully replaced your HP Laptop 15-bw0xx battery.
다른 3명이 해당 안내서를 완성하였습니다.
Imani Kimbrough
회원 가입일: 09/14/20
199 평판
안내서 1개 작성함
University of Memphis, Team S4-G4, Kim Fall 2020 University of Memphis, Team S4-G4, Kim Fall 2020 회원
UM-KIM-F20S4G4
1 회원
안내서 1개 작성하였습니다
댓글 한 개
hello, any idea where I can get a genuine battery for this laptop?
Brian Mwangi - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 8
30일 전: 51
전체 시간: 3,105
