주요 콘텐츠로 건너뛰기
HP 15-da0002dx RAM Replacement
필요한 것
  1. HP 15-da0002dx RAM Replacement, Back Cover: 1 단계, 이미지 1/1
    • Make sure the computer is completely turned off.
  2. HP 15-da0002dx RAM Replacement: 2 단계, 이미지 1/1
    • Turn over the laptop.
    • The HP label should be touching the table and the bottom cover should be facing up.
  3. HP 15-da0002dx RAM Replacement: 3 단계, 이미지 1/2 HP 15-da0002dx RAM Replacement: 3 단계, 이미지 2/2
    • Two plastic feet are located on adjacent sides of the back cover.
    • Peel back the plastic feet using the plastic opening tools.
  4. HP 15-da0002dx RAM Replacement: 4 단계, 이미지 1/1
    • Using the Phillips #1 screwdriver, unscrew the eleven 9.0 mm screws holding the back cover in place.
  5. HP 15-da0002dx RAM Replacement: 5 단계, 이미지 1/1
    • Carefully flip over the computer so the HP label is now facing the ceiling.
  6. HP 15-da0002dx RAM Replacement: 6 단계, 이미지 1/2 HP 15-da0002dx RAM Replacement: 6 단계, 이미지 2/2
    • Open the screen.
    • Run the plastic opening tools along the edge of the back cover. Do this until the back cover becomes loose.
  7. HP 15-da0002dx RAM Replacement: 7 단계, 이미지 1/1
    • Close the screen and flip over the laptop. Using the plastic opening tools, gently take off the back cover starting from the middle, bottom edge.
  8. HP 15-da0002dx RAM Replacement, Battery: 8 단계, 이미지 1/1
    • Remove the screws holding the battery in place using a Phillips #1 screwdriver.
  9. HP 15-da0002dx RAM Replacement: 9 단계, 이미지 1/2 HP 15-da0002dx RAM Replacement: 9 단계, 이미지 2/2
    • Using your fingers, tilt the top part of the battery towards you.
    • Continue to pull the rest of the battery away from the mounting tabs to remove.
  10. HP 15-da0002dx RAM Replacement, RAM: 10 단계, 이미지 1/1
    • The retention clips are located on either side of the RAM module. Spread them away from each other until you hear a clicking sound.
  11. HP 15-da0002dx RAM Replacement: 11 단계, 이미지 1/2 HP 15-da0002dx RAM Replacement: 11 단계, 이미지 2/2
    • Pull the RAM module away from the slot.
결론
다른 5명이 해당 안내서를 완성하였습니다.
Abigail Aron
회원 가입일: 09/04/19
941 평판
안내서 5개 작성하였습니다
University of Alabama, Team S2-G8, Bedsole Fall 2019 University of Alabama, Team S2-G8, Bedsole Fall 2019 회원
UA-BEDSOLE-F19S2G8
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 12
전체 시간: 1,298
