주요 콘텐츠로 건너뛰기
HP 15-da0012dx Battery Replacement
필요한 것
  1. HP 15-da0012dx Battery Replacement, Battery: 1 단계, 이미지 1/2 HP 15-da0012dx Battery Replacement, Battery: 1 단계, 이미지 2/2
    • Power down your laptop before proceeding.
    • Turn your laptop over so that the Laptop Identification Tag on the underside of the laptop faces the ceiling.
  2. HP 15-da0012dx Battery Replacement: 2 단계, 이미지 1/3 HP 15-da0012dx Battery Replacement: 2 단계, 이미지 2/3 HP 15-da0012dx Battery Replacement: 2 단계, 이미지 3/3
    • Using the plastic opening tools, peel back the plastic feet from the underside of the laptop.
  3. HP 15-da0012dx Battery Replacement: 3 단계, 이미지 1/2 HP 15-da0012dx Battery Replacement: 3 단계, 이미지 2/2
    • Using a Phillips #1 screwdriver, remove the eleven 9.0 mm screws holding the back cover in place.
  4. HP 15-da0012dx Battery Replacement: 4 단계, 이미지 1/2 HP 15-da0012dx Battery Replacement: 4 단계, 이미지 2/2
    • Slide the optical drive out of the computer.
  5. HP 15-da0012dx Battery Replacement: 5 단계, 이미지 1/3 HP 15-da0012dx Battery Replacement: 5 단계, 이미지 2/3 HP 15-da0012dx Battery Replacement: 5 단계, 이미지 3/3
    • Flip the computer over and open the screen.
    • Start from a corner and run the plastic opening tools along the edge of the back cover.
    • After the cover has been completely loosened around the entire perimeter, close the screen and flip the computer over.
    • Gently pry back the cover starting from the middle, bottom edge.
    • Make sure not to bend or crack the plastic cover.
  6. HP 15-da0012dx Battery Replacement: 6 단계, 이미지 1/2 HP 15-da0012dx Battery Replacement: 6 단계, 이미지 2/2
    • Using the Phillips #1 screwdriver, remove the three 8.0 mm screws holding the battery in place.
  7. HP 15-da0012dx Battery Replacement: 7 단계, 이미지 1/2 HP 15-da0012dx Battery Replacement: 7 단계, 이미지 2/2
    • Remove the battery by tilting the top of the battery towards you and pulling the battery away from the mounting tabs.
결론
다른 6명이 해당 안내서를 완성하였습니다.
Xavier Hung
회원 가입일: 02/07/19
914 평판
안내서 4개 작성하였습니다
UC Davis, Team S20-G4, Lore Winter 2019 UC Davis, Team S20-G4, Lore Winter 2019 회원
UCD-LORE-W19S20G4
3 회원들
안내서 7개 작성하였습니다
댓글 4개
Where to find, buy the same battery.
Divya Lekha - 답글
Where r living. We can help you which website you buy this battery
Mahima Singh -
Thank you for the guide! =D
Kevin - 답글
If you are living in Delhi ncr. We provide him service and delivery of hp ht03xl battery at very reasonable price at your office and home. Our home service executive will help you to assemble this battery. Nice description details about here. How to replace hp original battery.
Mahima Singh - 답글
댓글 쓰기
조회 통계:
24 시간 전: 7
7일 전: 24
30일 전: 172
전체 시간: 13,004
