소개
If your computer experiences choppy video playback, slow boot-ups, low memory messages, or beeps and fails to boot, use this guide to remove and replace the RAM module(s). You will need a plastic opening tool and a Phillips #1 screwdriver head.
필요한 것
Turn your laptop over so that the Laptop Identification Tag on the underside of the laptop faces the ceiling.
Flip the computer over and open the screen.
Start from a corner and run the plastic opening tools along the edge of the back cover.
After the cover has been completely loosened around the entire perimeter, close the screen and flip the computer over.
Gently pry back the cover starting from the middle, bottom edge.
다른 4명이 해당 안내서를 완성하였습니다.
