주요 콘텐츠로 건너뛰기
HP 15-da0012dx SSD Replacement
필요한 것
  1. HP 15-da0012dx SSD Replacement, Battery: 1 단계, 이미지 2개 중 1개 HP 15-da0012dx SSD Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Power down your laptop before proceeding.
    • Turn your laptop over so that the Laptop Identification Tag on the underside of the laptop faces the ceiling.
  2. HP 15-da0012dx SSD Replacement: 2 단계, 이미지 3개 중 1개 HP 15-da0012dx SSD Replacement: 2 단계, 이미지 3개 중 2개 HP 15-da0012dx SSD Replacement: 2 단계, 이미지 3개 중 3개
    • Using the plastic opening tools, peel back the plastic feet from the underside of the laptop.
  3. HP 15-da0012dx SSD Replacement: 3 단계, 이미지 2개 중 1개 HP 15-da0012dx SSD Replacement: 3 단계, 이미지 2개 중 2개
    • Using a Phillips #1 screwdriver, remove the eleven 9.0 mm screws holding the back cover in place.
  4. HP 15-da0012dx SSD Replacement: 4 단계, 이미지 2개 중 1개 HP 15-da0012dx SSD Replacement: 4 단계, 이미지 2개 중 2개
    • Slide the optical drive out of the computer.
  5. HP 15-da0012dx SSD Replacement: 5 단계, 이미지 3개 중 1개 HP 15-da0012dx SSD Replacement: 5 단계, 이미지 3개 중 2개 HP 15-da0012dx SSD Replacement: 5 단계, 이미지 3개 중 3개
    • Flip the computer over and open the screen.
    • Start from a corner and run the plastic opening tools along the edge of the back cover.
    • After the cover has been completely loosened around the entire perimeter, close the screen and flip the computer over.
    • Gently pry back the cover starting from the middle, bottom edge.
    • Make sure not to bend or crack the plastic cover.
  6. HP 15-da0012dx SSD Replacement: 6 단계, 이미지 2개 중 1개 HP 15-da0012dx SSD Replacement: 6 단계, 이미지 2개 중 2개
    • Using the Phillips #1 screwdriver, remove the three 8.0 mm screws holding the battery in place.
  7. HP 15-da0012dx SSD Replacement: 7 단계, 이미지 2개 중 1개 HP 15-da0012dx SSD Replacement: 7 단계, 이미지 2개 중 2개
    • Remove the battery by tilting the top of the battery towards you and pulling the battery away from the mounting tabs.
  8. HP 15-da0012dx SSD Replacement, SSD: 8 단계, 이미지 2개 중 1개 HP 15-da0012dx SSD Replacement, SSD: 8 단계, 이미지 2개 중 2개
    • Using the Phillips #1 screwdriver, remove the single 3.0 mm screw holding the SSD module in place.
  9. HP 15-da0012dx SSD Replacement: 9 단계, 이미지 2개 중 1개 HP 15-da0012dx SSD Replacement: 9 단계, 이미지 2개 중 2개
    • Pull the SSD module away from the socket.
결론
다른 7명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Xavier Hung
회원 가입일: 02/07/19
995 평판
안내서 4개를 작성함
UC Davis, Team S20-G4, Lore Winter 2019 UC Davis, Team S20-G4, Lore Winter 2019 회원
UCD-LORE-W19S20G4
3 회원들
안내서 7개를 작성함
1가이드 댓글
Nice explanation about how to disassemble of hp laptop and assembly of SSD again in this video. Thanks this help me a lot. If you need assistance in Delhi ncr. Kindly call us
Mahima Singh - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 18
지난 30일: 84
전체 시간: 10,174
