주요 콘텐츠로 건너뛰기
HP 15-da0012dx Screen Replacement
필요한 것
  1. HP 15-da0012dx Screen Replacement, Battery: 1 단계, 이미지 1/2 HP 15-da0012dx Screen Replacement, Battery: 1 단계, 이미지 2/2
    • Power down your laptop before proceeding.
    • Turn your laptop over so that the Laptop Identification Tag on the underside of the laptop faces the ceiling.
  2. HP 15-da0012dx Screen Replacement: 2 단계, 이미지 1/3 HP 15-da0012dx Screen Replacement: 2 단계, 이미지 2/3 HP 15-da0012dx Screen Replacement: 2 단계, 이미지 3/3
    • Using the plastic opening tools, peel back the plastic feet from the underside of the laptop.
  3. HP 15-da0012dx Screen Replacement: 3 단계, 이미지 1/2 HP 15-da0012dx Screen Replacement: 3 단계, 이미지 2/2
    • Using a Phillips #1 screwdriver, remove the eleven 9.0 mm screws holding the back cover in place.
  4. HP 15-da0012dx Screen Replacement: 4 단계, 이미지 1/2 HP 15-da0012dx Screen Replacement: 4 단계, 이미지 2/2
    • Slide the optical drive out of the computer.
  5. HP 15-da0012dx Screen Replacement: 5 단계, 이미지 1/3 HP 15-da0012dx Screen Replacement: 5 단계, 이미지 2/3 HP 15-da0012dx Screen Replacement: 5 단계, 이미지 3/3
    • Flip the computer over and open the screen.
    • Start from a corner and run the plastic opening tools along the edge of the back cover.
    • After the cover has been completely loosened around the entire perimeter, close the screen and flip the computer over.
    • Gently pry back the cover starting from the middle, bottom edge.
    • Make sure not to bend or crack the plastic cover.
  6. HP 15-da0012dx Screen Replacement: 6 단계, 이미지 1/2 HP 15-da0012dx Screen Replacement: 6 단계, 이미지 2/2
    • Using the Phillips #1 screwdriver, remove the three 8.0 mm screws holding the battery in place.
  7. HP 15-da0012dx Screen Replacement: 7 단계, 이미지 1/2 HP 15-da0012dx Screen Replacement: 7 단계, 이미지 2/2
    • Remove the battery by tilting the top of the battery towards you and pulling the battery away from the mounting tabs.
  8. HP 15-da0012dx Screen Replacement, Screen: 8 단계, 이미지 1/2 HP 15-da0012dx Screen Replacement, Screen: 8 단계, 이미지 2/2
    • Remove the 3 mm Phillips #0 screw securing the WLAN card in place.
    • Carefully remove the WLAN card from the motherboard.
    • Gently remove the antenna cable from the wire guides in the speaker and chassis.
    • Place WLAN card off to the side being careful not to pull on the antenna cable.
    • The antenna cable is soft and can easily be damaged.
  9. HP 15-da0012dx Screen Replacement: 9 단계, 이미지 1/3 HP 15-da0012dx Screen Replacement: 9 단계, 이미지 2/3 HP 15-da0012dx Screen Replacement: 9 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Carefully use the metal tweezers to remove the display connection to the motherboard.
  10. HP 15-da0012dx Screen Replacement: 10 단계, 이미지 1/3 HP 15-da0012dx Screen Replacement: 10 단계, 이미지 2/3 HP 15-da0012dx Screen Replacement: 10 단계, 이미지 3/3
    • Use the Phillips #1 screwdriver to disconnect the display hinges from the base of the laptop.
  11. HP 15-da0012dx Screen Replacement: 11 단계, 이미지 1/2 HP 15-da0012dx Screen Replacement: 11 단계, 이미지 2/2
    • Making sure to hold both the base and the screen, partially open laptop.
    • Carefully remove screen from laptop, making sure that the WLAN card is safely removed with it.
  12. HP 15-da0012dx Screen Replacement: 12 단계, 이미지 1/3 HP 15-da0012dx Screen Replacement: 12 단계, 이미지 2/3 HP 15-da0012dx Screen Replacement: 12 단계, 이미지 3/3
    • Carefully use the pry tool to separate the screen side of the hinge cover from the screen.
    • Rotate the hinge cover away from the screen to remove it from the screen.
  13. HP 15-da0012dx Screen Replacement: 13 단계, 이미지 1/3 HP 15-da0012dx Screen Replacement: 13 단계, 이미지 2/3 HP 15-da0012dx Screen Replacement: 13 단계, 이미지 3/3
    • Starting from the area near the hinges, gently remove the adhesive display bezel from around the screen using the iFixit opening tool.
  14. HP 15-da0012dx Screen Replacement: 14 단계, 이미지 1/2 HP 15-da0012dx Screen Replacement: 14 단계, 이미지 2/2
    • Use the Phillips #1 screwdriver to remove the four 3.0 mm screws securing the screen to the top cover.
  15. HP 15-da0012dx Screen Replacement: 15 단계, 이미지 1/2 HP 15-da0012dx Screen Replacement: 15 단계, 이미지 2/2
    • Carefully lift the screen, being aware to not pull on the display cable connecting the screen to the top cover.
    • Gently remove the display cable from the back of the screen.
    • Remove the screen from the display assembly.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Chase Wilson
회원 가입일: 10/02/19
349 평판
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 8
30일 전: 38
전체 시간: 3,485
