주요 콘텐츠로 건너뛰기
HP 15-db0004dx Battery Replacement
필요한 것
  1. HP 15-db0004dx Battery Replacement, Bottom Case: 1 단계, 이미지 1/2 HP 15-db0004dx Battery Replacement, Bottom Case: 1 단계, 이미지 2/2
    • Turn the laptop off and unplug it before starting.
    • Flip your laptop over, face down.
  2. HP 15-db0004dx Battery Replacement: 2 단계, 이미지 1/1
    • Peel off the two long rubber grips running lengthwise on the laptop.
  3. HP 15-db0004dx Battery Replacement: 3 단계, 이미지 1/2 HP 15-db0004dx Battery Replacement: 3 단계, 이미지 2/2
    • Using a Phillips #000 screwdriver, remove the eleven 10 mm screws located on the underside of the laptop, that are holding the back panel in place.
  4. HP 15-db0004dx Battery Replacement: 4 단계, 이미지 1/1
    • Carefully slide the optical drive out of the laptop.
  5. HP 15-db0004dx Battery Replacement: 5 단계, 이미지 1/1
    • Use a plastic opening tool to separate the back panel from the laptop.
    • For an easier removal, start at the corner and run the tool along the edge of the cover.
    • If you do not have a plastic opening tool, open it carefully using your hands, as shown.
    • Be careful to not bend the back panel, or to not apply too much pressure and force, doing so could cause the panel to break.
  6. HP 15-db0004dx Battery Replacement, Battery: 6 단계, 이미지 1/2 HP 15-db0004dx Battery Replacement, Battery: 6 단계, 이미지 2/2
    • Using the Philips #000 screwdriver remove all of the six 5mm screws.
  7. HP 15-db0004dx Battery Replacement: 7 단계, 이미지 1/3 HP 15-db0004dx Battery Replacement: 7 단계, 이미지 2/3 HP 15-db0004dx Battery Replacement: 7 단계, 이미지 3/3
    • Disconnect the battery connector.
    • Slide the battery up and out.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Jordyn Carter
회원 가입일: 09/22/22
112 평판
안내서 1개 작성함
University of North Texas, Team 4-5, Saru Jimmy Fall 2022 University of North Texas, Team 4-5, Saru Jimmy Fall 2022 회원
UNT-SARU JIMMY-F22S4G5
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 18
전체 시간: 653
