소개
Following this guide will help you remove and replace the battery in your HP 15-db0015dx.
Reasons for battery replacement:
- Computer won’t turn on without being plugged in.
- Battery doesn’t seem to hold a charge.
Replacing the battery will alleviate these issues and lengthen the lifespan of your laptop.
필요한 것
Power off the device before starting.
Remove the rubber strips that hide the screws using the spudger.
Flip the device and unscrew the eleven screws with a Phillips #0 screwdriver.
다른 8명이 해당 안내서를 완성하였습니다.
댓글 한 개
Dobrej schanim zakladovou desku na HP Pavilion 15-db005dx Palmrest ,
Mohli bysta mi poradit kde ji koupim predem dekuji za odpoved.
