주요 콘텐츠로 건너뛰기
HP 15-db0015dx Hard Drive Replacement
필요한 것
  1. HP 15-db0015dx Hard Drive Replacement, Battery: 1 단계, 이미지 1/2 HP 15-db0015dx Hard Drive Replacement, Battery: 1 단계, 이미지 2/2
    • Power off the device before starting.
    • Remove the rubber strips that hide the screws using the spudger.
    • Flip the device and unscrew the eleven screws with a Phillips #0 screwdriver.
  2. HP 15-db0015dx Hard Drive Replacement: 2 단계, 이미지 1/3 HP 15-db0015dx Hard Drive Replacement: 2 단계, 이미지 2/3 HP 15-db0015dx Hard Drive Replacement: 2 단계, 이미지 3/3
    • Use the spudger tool to pry open the back cover.
    • Lift the back panel to access the inside.
    • Slide the CD drive to the left, and remove.
  3. HP 15-db0015dx Hard Drive Replacement: 3 단계, 이미지 1/3 HP 15-db0015dx Hard Drive Replacement: 3 단계, 이미지 2/3 HP 15-db0015dx Hard Drive Replacement: 3 단계, 이미지 3/3
    • Unscrew the three battery screws with a Phillips #0 screwdriver.
    • Lift the battery up, disconnecting the connector first.
    • Push forward and remove the battery.
  4. HP 15-db0015dx Hard Drive Replacement, Hard Drive: 4 단계, 이미지 1/3 HP 15-db0015dx Hard Drive Replacement, Hard Drive: 4 단계, 이미지 2/3 HP 15-db0015dx Hard Drive Replacement, Hard Drive: 4 단계, 이미지 3/3
    • Remove the four screws on the hard drive bracket with a Phillips #0 screwdriver.
    • Pull the hard drive bracket out.
  5. HP 15-db0015dx Hard Drive Replacement: 5 단계, 이미지 1/1
    • Remove the hard drive from the connector by sliding it to the left until the connector is disengaged.
결론
다른 6명이 해당 안내서를 완성하였습니다.
Steven Dankiewicz
회원 가입일: 01/29/20
436 평판
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 8
30일 전: 46
전체 시간: 3,977
