주요 콘텐츠로 건너뛰기
HP 15-db0015dx USB/SD Card Reader Replacement
필요한 것
  1. HP 15-db0015dx USB/SD Card Reader Replacement, Battery: 1 단계, 이미지 2개 중 1개 HP 15-db0015dx USB/SD Card Reader Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Power off the device before starting.
    • Remove the rubber strips that hide the screws using the spudger.
    • Flip the device and unscrew the eleven screws with a Phillips #0 screwdriver.
  2. HP 15-db0015dx USB/SD Card Reader Replacement: 2 단계, 이미지 3개 중 1개 HP 15-db0015dx USB/SD Card Reader Replacement: 2 단계, 이미지 3개 중 2개 HP 15-db0015dx USB/SD Card Reader Replacement: 2 단계, 이미지 3개 중 3개
    • Use the spudger tool to pry open the back cover.
    • Lift the back panel to access the inside.
    • Slide the CD drive to the left, and remove.
  3. HP 15-db0015dx USB/SD Card Reader Replacement: 3 단계, 이미지 3개 중 1개 HP 15-db0015dx USB/SD Card Reader Replacement: 3 단계, 이미지 3개 중 2개 HP 15-db0015dx USB/SD Card Reader Replacement: 3 단계, 이미지 3개 중 3개
    • Unscrew the three battery screws with a Phillips #0 screwdriver.
    • Lift the battery up, disconnecting the connector first.
    • Push forward and remove the battery.
  4. HP 15-db0015dx USB/SD Card Reader Replacement, Hard Drive: 4 단계, 이미지 3개 중 1개 HP 15-db0015dx USB/SD Card Reader Replacement, Hard Drive: 4 단계, 이미지 3개 중 2개 HP 15-db0015dx USB/SD Card Reader Replacement, Hard Drive: 4 단계, 이미지 3개 중 3개
    • Remove the four screws on the hard drive bracket with a Phillips #0 screwdriver.
    • Pull the hard drive bracket out.
  5. HP 15-db0015dx USB/SD Card Reader Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the hard drive from the connector by sliding it to the left until the connector is disengaged.
  6. HP 15-db0015dx USB/SD Card Reader Replacement, USB/SD Card Reader: 6 단계, 이미지 3개 중 1개 HP 15-db0015dx USB/SD Card Reader Replacement, USB/SD Card Reader: 6 단계, 이미지 3개 중 2개 HP 15-db0015dx USB/SD Card Reader Replacement, USB/SD Card Reader: 6 단계, 이미지 3개 중 3개
    • Lift up on the connector pin that attaches the SD card reader to the motherboard
    • Gently pull the wire out
  7. HP 15-db0015dx USB/SD Card Reader Replacement: 7 단계, 이미지 2개 중 1개 HP 15-db0015dx USB/SD Card Reader Replacement: 7 단계, 이미지 2개 중 2개
    • Snake the wire underneath the battery support
    • Pull the wire out to allow the SD Card reader to be removed
  8. HP 15-db0015dx USB/SD Card Reader Replacement: 8 단계, 이미지 3개 중 1개 HP 15-db0015dx USB/SD Card Reader Replacement: 8 단계, 이미지 3개 중 2개 HP 15-db0015dx USB/SD Card Reader Replacement: 8 단계, 이미지 3개 중 3개
    • Remove the two Phillips #0 screws holding the SD Card reader in place.
    • Gently pull the SD card reader up and out of the slot.
    • A spudger may have to be used to pop the SD card reader out of place.
결론
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 11
전체 시간: 655
