주요 콘텐츠로 건너뛰기
HP 15-db0015dx WLAN Module Replacement
필요한 것
  1. HP 15-db0015dx WLAN Module Replacement, Battery: 1 단계, 이미지 1/2 HP 15-db0015dx WLAN Module Replacement, Battery: 1 단계, 이미지 2/2
    • Power off the device before starting.
    • Remove the rubber strips that hide the screws using the spudger.
    • Flip the device and unscrew the eleven screws with a Phillips #0 screwdriver.
  2. HP 15-db0015dx WLAN Module Replacement: 2 단계, 이미지 1/3 HP 15-db0015dx WLAN Module Replacement: 2 단계, 이미지 2/3 HP 15-db0015dx WLAN Module Replacement: 2 단계, 이미지 3/3
    • Use the spudger tool to pry open the back cover.
    • Lift the back panel to access the inside.
    • Slide the CD drive to the left, and remove.
  3. HP 15-db0015dx WLAN Module Replacement: 3 단계, 이미지 1/3 HP 15-db0015dx WLAN Module Replacement: 3 단계, 이미지 2/3 HP 15-db0015dx WLAN Module Replacement: 3 단계, 이미지 3/3
    • Unscrew the three battery screws with a Phillips #0 screwdriver.
    • Lift the battery up, disconnecting the connector first.
    • Push forward and remove the battery.
  4. HP 15-db0015dx WLAN Module Replacement, WLAN Module: 4 단계, 이미지 1/1
    • Disconnect the wire attached to the WLAN card by prying it upward from the card.
  5. HP 15-db0015dx WLAN Module Replacement: 5 단계, 이미지 1/1
    • Remove the screw holding down the card with a Phillips #0 screwdriver.
  6. HP 15-db0015dx WLAN Module Replacement: 6 단계, 이미지 1/2 HP 15-db0015dx WLAN Module Replacement: 6 단계, 이미지 2/2
    • Pull the WLAN Module out of the connection port.
결론
Daniel McGuire
회원 가입일: 01/29/20
193 평판
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 7
전체 시간: 467
