주요 콘텐츠로 건너뛰기
HP 15-dw2065st Fan Replacement
필요한 것
  1. HP 15-dw2065st Fan Replacement, Fan: 1 단계, 이미지 1/2 HP 15-dw2065st Fan Replacement, Fan: 1 단계, 이미지 2/2
    • Press the top left button to turn the laptop off.
    • Make sure the laptop is unplugged.
    • The light on the left side of the base of the laptop indicates if the laptop is on or off.
  2. HP 15-dw2065st Fan Replacement: 2 단계, 이미지 1/3 HP 15-dw2065st Fan Replacement: 2 단계, 이미지 2/3 HP 15-dw2065st Fan Replacement: 2 단계, 이미지 3/3
    • Close the screen and flip the laptop over so the backside is facing up.
    • Using a Phillips screwdriver, remove the left and right corner screws.
  3. HP 15-dw2065st Fan Replacement: 3 단계, 이미지 1/3 HP 15-dw2065st Fan Replacement: 3 단계, 이미지 2/3 HP 15-dw2065st Fan Replacement: 3 단계, 이미지 3/3
    • Use a spudger or your fingers to remove the protective padding from the top and bottom of the base and expose the screws.
    • With a Phillips screwdriver, remove the five screws from the base.
  4. HP 15-dw2065st Fan Replacement: 4 단계, 이미지 1/3 HP 15-dw2065st Fan Replacement: 4 단계, 이미지 2/3 HP 15-dw2065st Fan Replacement: 4 단계, 이미지 3/3
    • Open the screen.
    • Use a spudger to pry the palm rest assembly from the laptop.
    • Work the spudger around the perimeter to release the clips that secure the palm rest assembly.
    • Remove the palm rest assembly carefully as there are ribbon cables attached on the other side.
  5. HP 15-dw2065st Fan Replacement: 5 단계, 이미지 1/2 HP 15-dw2065st Fan Replacement: 5 단계, 이미지 2/2
    • With a Phillips screwdriver, remove the four screws securing the battery.
    • Remove the battery from the connector.
  6. HP 15-dw2065st Fan Replacement: 6 단계, 이미지 1/1
    • Use a spudger to lift the black locking flap.
    • Remove the ribbon cable.
  7. HP 15-dw2065st Fan Replacement: 7 단계, 이미지 1/3 HP 15-dw2065st Fan Replacement: 7 단계, 이미지 2/3 HP 15-dw2065st Fan Replacement: 7 단계, 이미지 3/3
    • Remove the black screw from the fan.
    • Pull the cable away from the connector in the same direction that the individual wires are running
    • Pull evenly on the full width of the cable so that no individual wires are overly strained.
    • Remove the fan.
  8. HP 15-dw2065st Fan Replacement: 8 단계, 이미지 1/2 HP 15-dw2065st Fan Replacement: 8 단계, 이미지 2/2
    • Set the new fan in place.
    • Plug in the new fan.
    • Screw in the new fan.
    • Return all parts to the base.
    • Close the base.
결승점
Jonathan Bentley
회원 가입일: 05/24/23
157 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 13
전체 시간: 168
