소개
This guide will show you how to replace the display assembly for an HP 15-dy2024nr.
Indications of a bad screen include a large crack in the screen, no response, dim light, large rainbow lines, and dots.
Before removing any part of the computer ensure that the laptop is turned off and disconnected from any power source.
필요한 것
Peel the inner edge of the bezel using an opening tool and gently snap both edges away from the glass.
Go around the perimeter and begin snapping the tabs underneath.
다른 2명이 해당 안내서를 완성하였습니다.
