주요 콘텐츠로 건너뛰기
HP 15-dy2024nr Fan Assembly Replacement
필요한 것
  1. HP 15-dy2024nr Fan Assembly Replacement, Back Cover: 1 단계, 이미지 1/2 HP 15-dy2024nr Fan Assembly Replacement, Back Cover: 1 단계, 이미지 2/2
    • Use a spudger to peel one corner of each of the rubber feet from the bottom of the laptop.
    • Gently peel the feet from the laptop using the spudger revealing the screws underneath.
    • If the rubber foot peels away but leaves adhesive behind you must peel the adhesive away before removing the screws.
  2. HP 15-dy2024nr Fan Assembly Replacement: 2 단계, 이미지 1/3 HP 15-dy2024nr Fan Assembly Replacement: 2 단계, 이미지 2/3 HP 15-dy2024nr Fan Assembly Replacement: 2 단계, 이미지 3/3
    • Use a Phillips #1 screwdriver to remove:
    • Two 2.5mm x 6mm screws
    • Six 2mm x 6mm screws
    • Be sure to keep different screw sizes separated.
  3. HP 15-dy2024nr Fan Assembly Replacement: 3 단계, 이미지 1/3 HP 15-dy2024nr Fan Assembly Replacement: 3 단계, 이미지 2/3 HP 15-dy2024nr Fan Assembly Replacement: 3 단계, 이미지 3/3
    • Insert an iFixit opening tool into the seam between the keyboard area and bottom cover.
    • Using another iFixit opening tool, slide along the seam to unhook the clips.
    • There are clips all the way around the seam. You may hear a popping sound as the clips come loose. This step may require some force to separate the back cover from the laptop.
    • When the front of the laptop is open, you can use your finger to hold a corner open then slide an iFixit opening tool along the seam toward the back corner.
    • After the clips have been released, flip the laptop over and lift the cover.
  4. HP 15-dy2024nr Fan Assembly Replacement, Battery: 4 단계, 이미지 1/3 HP 15-dy2024nr Fan Assembly Replacement, Battery: 4 단계, 이미지 2/3 HP 15-dy2024nr Fan Assembly Replacement, Battery: 4 단계, 이미지 3/3
    • Remove five 2.0mm x 3.0mm screws using a Phillips #00 screwdriver.
    • Use the iFixit opening picks to lift the battery away from the laptop.
  5. HP 15-dy2024nr Fan Assembly Replacement: 5 단계, 이미지 1/3 HP 15-dy2024nr Fan Assembly Replacement: 5 단계, 이미지 2/3 HP 15-dy2024nr Fan Assembly Replacement: 5 단계, 이미지 3/3
    • Be aware that the battery is plugged into the motherboard.
    • Unplug the battery from the motherboard.
    • Lift the battery away from the laptop and remove.
  6. HP 15-dy2024nr Fan Assembly Replacement, Fan Assembly: 6 단계, 이미지 1/2 HP 15-dy2024nr Fan Assembly Replacement, Fan Assembly: 6 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • If your fan needs to be cleaned, do that now. If it is not working properly, continue with these steps to remove the broken fan.
    • Use the nylon tipped reverse tweezers to lift the cables up from off the motherboard before attempting to disconnect the connector from the motherboard.
    • Do not use the tweezers to pull the cables off the motherboard.
  7. HP 15-dy2024nr Fan Assembly Replacement: 7 단계, 이미지 1/2 HP 15-dy2024nr Fan Assembly Replacement: 7 단계, 이미지 2/2
    • Wedge the Halberd spudger between the black plastic connector and the motherboard.
    • Lightly twist the spudger blade up. The connector should pop off.
  8. HP 15-dy2024nr Fan Assembly Replacement: 8 단계, 이미지 1/3 HP 15-dy2024nr Fan Assembly Replacement: 8 단계, 이미지 2/3 HP 15-dy2024nr Fan Assembly Replacement: 8 단계, 이미지 3/3
    • Remove the three chrome-plated 2.0mm x 3.0mm screws holding the fan assembly in place using a Phillips #0 screwdriver.
    • Lift the fan assembly out of the laptop.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Nathaniel Reeves
회원 가입일: 09/27/22
366 평판
안내서 2개 작성하였습니다
Utah Tech University, Team 1-4, McMurrin Fall 2022 Utah Tech University, Team 1-4, McMurrin Fall 2022 회원
UTAHTECH-MCMURRIN-F22S1G4
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 6
7일 전: 8
30일 전: 20
전체 시간: 207
