주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HP 15-dy2024nr SSD Replacement
필요한 것
  1. HP 15-dy2024nr SSD Replacement, Back Cover: 1 단계, 이미지 2개 중 1개 HP 15-dy2024nr SSD Replacement, Back Cover: 1 단계, 이미지 2개 중 2개
    • Use a spudger to peel one corner of each of the rubber feet from the bottom of the laptop.
    • Gently peel the feet from the laptop using the spudger revealing the screws underneath.
    • If the rubber foot peels away but leaves adhesive behind you must peel the adhesive away before removing the screws.
  2. HP 15-dy2024nr SSD Replacement: 2 단계, 이미지 3개 중 1개 HP 15-dy2024nr SSD Replacement: 2 단계, 이미지 3개 중 2개 HP 15-dy2024nr SSD Replacement: 2 단계, 이미지 3개 중 3개
    • Use a Phillips #1 screwdriver to remove:
    • Two 2.5mm x 6mm screws
    • Six 2mm x 6mm screws
    • Be sure to keep different screw sizes separated.
  3. HP 15-dy2024nr SSD Replacement: 3 단계, 이미지 3개 중 1개 HP 15-dy2024nr SSD Replacement: 3 단계, 이미지 3개 중 2개 HP 15-dy2024nr SSD Replacement: 3 단계, 이미지 3개 중 3개
    • Insert an iFixit opening tool into the seam between the keyboard area and bottom cover.
    • Using another iFixit opening tool, slide along the seam to unhook the clips.
    • There are clips all the way around the seam. You may hear a popping sound as the clips come loose. This step may require some force to separate the back cover from the laptop.
    • When the front of the laptop is open, you can use your finger to hold a corner open then slide an iFixit opening tool along the seam toward the back corner.
    • After the clips have been released, flip the laptop over and lift the cover.
  4. HP 15-dy2024nr SSD Replacement, Battery: 4 단계, 이미지 3개 중 1개 HP 15-dy2024nr SSD Replacement, Battery: 4 단계, 이미지 3개 중 2개 HP 15-dy2024nr SSD Replacement, Battery: 4 단계, 이미지 3개 중 3개
    • Remove five 2.0mm x 3.0mm screws using a Phillips #00 screwdriver.
    • Use the iFixit opening picks to lift the battery away from the laptop.
  5. HP 15-dy2024nr SSD Replacement: 5 단계, 이미지 3개 중 1개 HP 15-dy2024nr SSD Replacement: 5 단계, 이미지 3개 중 2개 HP 15-dy2024nr SSD Replacement: 5 단계, 이미지 3개 중 3개
    • Be aware that the battery is plugged into the motherboard.
    • Unplug the battery from the motherboard.
    • Lift the battery away from the laptop and remove.
  6. HP 15-dy2024nr SSD Replacement, SSD: 6 단계, 이미지 2개 중 1개 HP 15-dy2024nr SSD Replacement, SSD: 6 단계, 이미지 2개 중 2개
    • Remove the single 2 mm screw from the hard drive using a Phillips #00 screwdriver.
  7. HP 15-dy2024nr SSD Replacement: 7 단계, 이미지 2개 중 1개 HP 15-dy2024nr SSD Replacement: 7 단계, 이미지 2개 중 2개
    • Pull the SSD away from the connector, while gently lifting it out using your hands.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Konnor Young
회원 가입일: 09/27/22
580 평판
안내서 4개를 작성함
Utah Tech University, Team 1-4, McMurrin Fall 2022 Utah Tech University, Team 1-4, McMurrin Fall 2022 회원
UTAHTECH-MCMURRIN-F22S1G4
3 회원들
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 7
지난 30일: 54
전체 시간: 1,318
