주요 콘텐츠로 건너뛰기
HP 15-dy2702dx Fan Replacement
필요한 것
  1. HP 15-dy2702dx Fan Replacement, Lower Case: 1 단계, 이미지 1/1
    • Remove both of the rubber strips to uncover the hidden screws.
    • You can use a prying tool to help lift an end.
  2. HP 15-dy2702dx Fan Replacement: 2 단계, 이미지 1/1
    • Unscrew all 8 Phillips #0 screws on the bottom panel:
    • Two M2.5x6
    • Six M2x6
  3. HP 15-dy2702dx Fan Replacement: 3 단계, 이미지 1/2 HP 15-dy2702dx Fan Replacement: 3 단계, 이미지 2/2
    • Flip the laptop over and open the lid.
    • Separate the bottom panel from the main body by using the iFixit opening tool.
    • Ensure that the bottom panel is completely separated along the edges.
  4. HP 15-dy2702dx Fan Replacement: 4 단계, 이미지 1/2 HP 15-dy2702dx Fan Replacement: 4 단계, 이미지 2/2
    • If you can lift the laptop like shown in the first picture, the bottom panel is nearly separated.
    • Close the laptop to allow the back edges to fully separate
  5. HP 15-dy2702dx Fan Replacement: 5 단계, 이미지 1/3 HP 15-dy2702dx Fan Replacement: 5 단계, 이미지 2/3 HP 15-dy2702dx Fan Replacement: 5 단계, 이미지 3/3
    • Flip the laptop over and carefully remove the lower case.
  6. HP 15-dy2702dx Fan Replacement, Fan: 6 단계, 이미지 1/3 HP 15-dy2702dx Fan Replacement, Fan: 6 단계, 이미지 2/3 HP 15-dy2702dx Fan Replacement, Fan: 6 단계, 이미지 3/3
    • Use a Phillips #0 screwdriver to unscrew the three screws that secure the fan.
    • These screws sizes are M2x6.
  7. HP 15-dy2702dx Fan Replacement: 7 단계, 이미지 1/1
    • Grip the cord that connects the fan to the motherboard and gently pull out to disconnect the cable from the connector.
    • Alternatively, we recommend using a tool to push the connector out of its socket to avoid damaging the wires.
  8. HP 15-dy2702dx Fan Replacement: 8 단계, 이미지 1/2 HP 15-dy2702dx Fan Replacement: 8 단계, 이미지 2/2
    • Gently lift the fan to remove it from the case.
결론
September Oo
회원 가입일: 09/07/23
373 평판
안내서 4개 작성하였습니다
Gateway, Team 1-4, Pee Fall 2023 Gateway, Team 1-4, Pee Fall 2023 회원
GCC-PEE-F23S1G4
4 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 11
전체 시간: 87
