주요 콘텐츠로 건너뛰기
HP 15-ef2025nr RAM Replacement
필요한 것
  1. HP 15-ef2025nr RAM Replacement, Battery: 1 단계, 이미지 1/1
    • Turn the laptop upside down with the hinge facing you.
  2. HP 15-ef2025nr RAM Replacement: 2 단계, 이미지 1/2 HP 15-ef2025nr RAM Replacement: 2 단계, 이미지 2/2
    • Use an opening tool to remove the rubber strips by prying up a corner and gently pulling off the strip.
  3. HP 15-ef2025nr RAM Replacement: 3 단계, 이미지 1/2 HP 15-ef2025nr RAM Replacement: 3 단계, 이미지 2/2
    • Use a Phillips screwdriver to remove the eight 3 mm screws (including the 2 screws that were not under the rubber strips) securing the lower case.
  4. HP 15-ef2025nr RAM Replacement: 4 단계, 이미지 1/2 HP 15-ef2025nr RAM Replacement: 4 단계, 이미지 2/2
    • Flip the laptop over and open the lid.
    • Insert an opening tool into the seam between the edge of the lower case and the chassis.
    • Gently pry around the entire perimeter until the lower case separates from the chassis.
    • Close the lid and flip the laptop back over.
    • Remove the lower case.
  5. HP 15-ef2025nr RAM Replacement: 5 단계, 이미지 1/3 HP 15-ef2025nr RAM Replacement: 5 단계, 이미지 2/3 HP 15-ef2025nr RAM Replacement: 5 단계, 이미지 3/3
    • Remove the five 2 mm Phillips screws holding the battery down.
    • Take care not to puncture, bend, or twist the battery. Lithium batteries can be very volatile. Follow all proper hazardous disposal laws where you live.
    • Gently lift the front edge of the battery up to disconnect the socket.
    • Lift the battery up and out.
  6. HP 15-ef2025nr RAM Replacement, RAM: 6 단계, 이미지 1/3 HP 15-ef2025nr RAM Replacement, RAM: 6 단계, 이미지 2/3 HP 15-ef2025nr RAM Replacement, RAM: 6 단계, 이미지 3/3
    • Gently pry apart the two silver retention arms simultaneously.
    • The RAM module will pop up at a 45 degree angle.
    • Pull the RAM module directly out its socket.
결론
Maribella Rivera
회원 가입일: 02/13/23
327 평판
안내서 3개 작성하였습니다
Austin Community College, Team 1-1, Watkins Spring 2023 Austin Community College, Team 1-1, Watkins Spring 2023 회원
AUSTINCC-WATKINS-S23S1G1
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 24
전체 시간: 281
