주요 콘텐츠로 건너뛰기
HP 15-f009wm Motherboard Replacement
필요한 것
  1. HP 15-f009wm Motherboard Replacement, Battery: 1 단계, 이미지 1/2 HP 15-f009wm Motherboard Replacement, Battery: 1 단계, 이미지 2/2
    • Turn laptop upside down.
    • Flip the lock switch to the unlocked setting.
  2. HP 15-f009wm Motherboard Replacement: 2 단계, 이미지 1/3 HP 15-f009wm Motherboard Replacement: 2 단계, 이미지 2/3 HP 15-f009wm Motherboard Replacement: 2 단계, 이미지 3/3
    • Flip the release switch.
    • Once the flip is switched, the battery should pop out.
  3. HP 15-f009wm Motherboard Replacement: 3 단계, 이미지 1/2 HP 15-f009wm Motherboard Replacement: 3 단계, 이미지 2/2
    • Slide the battery out.
  4. HP 15-f009wm Motherboard Replacement, RAM: 4 단계, 이미지 1/3 HP 15-f009wm Motherboard Replacement, RAM: 4 단계, 이미지 2/3 HP 15-f009wm Motherboard Replacement, RAM: 4 단계, 이미지 3/3
    • Remove the two Phillips #1 screws from the RAM panel.
  5. HP 15-f009wm Motherboard Replacement: 5 단계, 이미지 1/3 HP 15-f009wm Motherboard Replacement: 5 단계, 이미지 2/3 HP 15-f009wm Motherboard Replacement: 5 단계, 이미지 3/3
    • Use the plastic opening tool to pop the panel off.
  6. HP 15-f009wm Motherboard Replacement: 6 단계, 이미지 1/3 HP 15-f009wm Motherboard Replacement: 6 단계, 이미지 2/3 HP 15-f009wm Motherboard Replacement: 6 단계, 이미지 3/3
    • Release the tabs on each side of the chip by simultaneously pushing each tab away from the RAM.
    • These tabs lock the chip in place and releasing them will cause the chip to "pop" up.
  7. HP 15-f009wm Motherboard Replacement: 7 단계, 이미지 1/1
    • Remove the RAM chip from the laptop.
  8. HP 15-f009wm Motherboard Replacement, Hard Drive: 8 단계, 이미지 1/1
    • Remove the sixteen 7mm Phillips #1 screws from the bottom panel.
  9. HP 15-f009wm Motherboard Replacement: 9 단계, 이미지 1/3 HP 15-f009wm Motherboard Replacement: 9 단계, 이미지 2/3 HP 15-f009wm Motherboard Replacement: 9 단계, 이미지 3/3
    • Pull the disk drive out of the laptop.
  10. HP 15-f009wm Motherboard Replacement: 10 단계, 이미지 1/1
    • Remove the three 2mm Phillips #00 screws found underneath the disk drive.
  11. HP 15-f009wm Motherboard Replacement: 11 단계, 이미지 1/3 HP 15-f009wm Motherboard Replacement: 11 단계, 이미지 2/3 HP 15-f009wm Motherboard Replacement: 11 단계, 이미지 3/3
    • Remove the single 4mm Phillips #1 screw from the Wi-Fi card.
    • Pull the Wi-Fi card out of the motherboard.
  12. HP 15-f009wm Motherboard Replacement: 12 단계, 이미지 1/3 HP 15-f009wm Motherboard Replacement: 12 단계, 이미지 2/3 HP 15-f009wm Motherboard Replacement: 12 단계, 이미지 3/3
    • Open the laptop.
    • Use a plastic opening tool to pop out the keyboard by starting at the top and working your way around the perimeter.
  13. HP 15-f009wm Motherboard Replacement: 13 단계, 이미지 1/2 HP 15-f009wm Motherboard Replacement: 13 단계, 이미지 2/2
    • Open the screen up until it lays flat and rotate the laptop until the screen is closest to you.
    • Lift the keyboard from the laptop.
    • Use a spudger to lift up the black latch on the ZIF connector and remove the ribbon cable.
  14. HP 15-f009wm Motherboard Replacement: 14 단계, 이미지 1/1
    • Remove the five 7mm Phillips #1 screws found underneath the keyboard.
  15. HP 15-f009wm Motherboard Replacement: 15 단계, 이미지 1/3 HP 15-f009wm Motherboard Replacement: 15 단계, 이미지 2/3 HP 15-f009wm Motherboard Replacement: 15 단계, 이미지 3/3
    • Use a spudger to lift the black tabs on the ZIF connectors.
    • Remove the ribbon cables from the ZIF connectors.
  16. HP 15-f009wm Motherboard Replacement: 16 단계, 이미지 1/3 HP 15-f009wm Motherboard Replacement: 16 단계, 이미지 2/3 HP 15-f009wm Motherboard Replacement: 16 단계, 이미지 3/3
    • Use a plastic opening tool to pop the palm rest off of the laptop.
    • Lift and remove the palm rest.
  17. HP 15-f009wm Motherboard Replacement: 17 단계, 이미지 1/3 HP 15-f009wm Motherboard Replacement: 17 단계, 이미지 2/3 HP 15-f009wm Motherboard Replacement: 17 단계, 이미지 3/3
    • Use a spudger to lift up the black latch on the ZIF connector.
    • Remove the USB/AUX port ribbon cable from the ZIF connector on the motherboard.
  18. HP 15-f009wm Motherboard Replacement: 18 단계, 이미지 1/2 HP 15-f009wm Motherboard Replacement: 18 단계, 이미지 2/2
    • Remove the single 7mm Phillips #1 screw from the USB/AUX board.
    • Remove the USB/AUX board from the laptop.
  19. HP 15-f009wm Motherboard Replacement: 19 단계, 이미지 1/3 HP 15-f009wm Motherboard Replacement: 19 단계, 이미지 2/3 HP 15-f009wm Motherboard Replacement: 19 단계, 이미지 3/3
    • Lift the Hard Drive from the laptop.
    • Disconnect the hard drive from the motherboard.
  20. HP 15-f009wm Motherboard Replacement, Motherboard: 20 단계, 이미지 1/2 HP 15-f009wm Motherboard Replacement, Motherboard: 20 단계, 이미지 2/2
    • Remove the four 4mm Phillips #1 screws from the motherboard.
    • Lift the motherboard up from the computer.
    • There will be three wires connected underneath.
  21. HP 15-f009wm Motherboard Replacement: 21 단계, 이미지 1/3 HP 15-f009wm Motherboard Replacement: 21 단계, 이미지 2/3 HP 15-f009wm Motherboard Replacement: 21 단계, 이미지 3/3
    • Disconnect the speaker.
  22. HP 15-f009wm Motherboard Replacement: 22 단계, 이미지 1/3 HP 15-f009wm Motherboard Replacement: 22 단계, 이미지 2/3 HP 15-f009wm Motherboard Replacement: 22 단계, 이미지 3/3
    • Remove the display connection wire. Lift the connection straight up from the motherboard.
  23. HP 15-f009wm Motherboard Replacement: 23 단계, 이미지 1/3 HP 15-f009wm Motherboard Replacement: 23 단계, 이미지 2/3 HP 15-f009wm Motherboard Replacement: 23 단계, 이미지 3/3
    • Flip the motherboard over.
    • Disconnect the charging port wire from the motherboard.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Alex Birchler
회원 가입일: 02/14/18
1,008 평판
안내서 5개 작성하였습니다
USF Tampa, Team S2-G2, Nance Spring 2018 USF Tampa, Team S2-G2, Nance Spring 2018 회원
USFT-NANCE-S18S2G2
4 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 4
30일 전: 21
전체 시간: 1,505
