주요 콘텐츠로 건너뛰기
HP 15-f033wm Battery Replacement
  1. HP 15-f033wm Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Turn power off using the power button located in the top left corner of the keyboard. Press and hold the power button for 3 seconds until it turns off.
  2. HP 15-f033wm Battery Replacement: 2 단계, 이미지 1/2 HP 15-f033wm Battery Replacement: 2 단계, 이미지 2/2
    • Close the laptop and flip it over so that the HP cover logo is on the underside of the laptop.
  3. HP 15-f033wm Battery Replacement: 3 단계, 이미지 1/2 HP 15-f033wm Battery Replacement: 3 단계, 이미지 2/2
    • Locate the battery and the two switches that release the battery when they are unlocked.
  4. HP 15-f033wm Battery Replacement: 4 단계, 이미지 1/2 HP 15-f033wm Battery Replacement: 4 단계, 이미지 2/2
    • Slide the left switch to the right so that the icon of a locked padlock is no longer visible and the icon of an unlocked padlock is now visible.
  5. HP 15-f033wm Battery Replacement: 5 단계, 이미지 1/3 HP 15-f033wm Battery Replacement: 5 단계, 이미지 2/3 HP 15-f033wm Battery Replacement: 5 단계, 이미지 3/3
    • With your left hand, slide the right switch to the left and hold it in place. This will unlock the battery and allow you to easily slide it out of its port.
    • While holding the switch in place, use your right hand to gently remove the battery from its port.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Aaron Chabot
회원 가입일: 10/17/17
620 평판
안내서 4개 작성하였습니다
UMass Dartmouth, Team S1-G4, Simcock Fall 2017 UMass Dartmouth, Team S1-G4, Simcock Fall 2017 회원
UMASSD-SIMCOCK-F17S1G4
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 9
전체 시간: 797
