소개
In the case that your CD reader is not processing the information embedded on the discs, follow this repair guide on replacing your CD reader.
필요한 것
Turn power off using the power button located in the top left corner of the keyboard. Press and hold the power button for 3 seconds until it turns off.
Remove the thirteen 7 mm PH1 Phillips head screws from the bottom of the laptop.
Remove metal bar on top of the CD drive. Do this by removing 3 mm PH1 Phillips head screw that is just below the bottom right corner of CD drive.
거의 끝나갑니다!
결론
