주요 콘텐츠로 건너뛰기
HP 15-f162dx Motherboard Replacement
필요한 것
  1. HP 15-f162dx Motherboard Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Pull back the lock.
  2. HP 15-f162dx Motherboard Replacement: 2 단계, 이미지 1개 중 1개
    • Take off the battery
  3. HP 15-f162dx Motherboard Replacement, Motherboard: 3 단계, 이미지 1개 중 1개
    • Use a Flathead 2.5 mm Phillips screwdriver to remove all of the screws on the backside of the laptop.
    • There are 14 screws on the back plate in total, make sure to remove them all before proceeding.
    • Apply gentle pressure when undoing the screws to preserve the condition of screw heads for future repairs or servicing.
  4. HP 15-f162dx Motherboard Replacement: 4 단계, 이미지 1개 중 1개
    • Once all screws have been removed , place the laptop on a flat surface and insert a metal spudger in a gap between the top side coverings.
    • Once inserted, move the spudger around the base, lifting the top edge about quarter of an inch. Gently go around the edge repeating the action.
    • The sharp popping sound that the latches on the inside will produce is normal and does not signify anything being broken.
    • While some force will be required in this step, make sure not to over-apply pressure since extra force might break the plastic latches.
    • After all of the inside latches have been dislodged, remove the front cover. Now is a good time to clean the dust that collects in the device after prolonged use.
  5. HP 15-f162dx Motherboard Replacement: 6 단계, 이미지 1개 중 1개
    • Use Phillips JIS J00 screwdriver to undo the screws that attach the motherboard to the back cover.
    • Again, make sure to apply only a gentle pressure when undoing the screws.
    • Be very careful: If the metal head of the screwdriver slips during the process, it can damage the motherboard. While not relevant in case of removing a broken motherboard, it is crucial while putting in a new one.
  6. HP 15-f162dx Motherboard Replacement: 7 단계, 이미지 3개 중 1개 HP 15-f162dx Motherboard Replacement: 7 단계, 이미지 3개 중 2개 HP 15-f162dx Motherboard Replacement: 7 단계, 이미지 3개 중 3개
    • Locate and disconnect the wires that are connected to the motherboard.
    • Do not use any kind of metal instrument to assist you in this process since it can damage the contacts of the wires.
    • Instead, you can use a credit card or a plastic spudger included in the Essential Electronics Toolkit.
    • After the wires have been disconnected, gently lift the motherboard out of the laptop.
결론
작성자
5다른 기여자 명과 함께
Abdulrahman Bogshan
회원 가입일: 10/02/18
322 평판
안내서 3개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 3
지난 30일: 12
전체 시간: 710
