주요 콘텐츠로 건너뛰기
부품
지정된 부품이 없습니다.
  1. Pull back the lock.
    • Pull back the lock.
  2. Take off the battery
    • Take off the battery
  3. Skip the upgrade.
    Take $10 off $50 with
    SKIPANDSAVE10
    Save Now
    Skip the upgrade.
    SKIPANDSAVE10
    Save Now
  4. Use phillips screwdriver flathead 2.5 mm to open the cover.
    • Use phillips screwdriver flathead 2.5 mm to open the cover.
  5. Use the Metal spudger set to gently open the front cover
    • Use the Metal spudger set to gently open the front cover
  6. Use phillips screwdriver JIS J00 to open the screws that holding the motherboard.
    • Use phillips screwdriver JIS J00 to open the screws that holding the motherboard.
  7. Pull out the wires connected to the motherboard, so that it is removable. Then, replace the motherboard. Pull out the wires connected to the motherboard, so that it is removable. Then, replace the motherboard. Pull out the wires connected to the motherboard, so that it is removable. Then, replace the motherboard.
    • Pull out the wires connected to the motherboard, so that it is removable. Then, replace the motherboard.
결론
Abdulrahman Bogshan
회원 가입일: 2018년 10월 02일
313 평판
안내서 3개 작성하였습니다
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 2
지난 30일: 11
전체 시간: 102
