주요 콘텐츠로 건너뛰기
HP 15-f162dx RAM Replacement
필요한 것
  1. HP 15-f162dx RAM Replacement, RAM: 1 단계, 이미지 1/1
    • Be sure to power off and unplug your device before you begin the repair.
  2. HP 15-f162dx RAM Replacement: 2 단계, 이미지 1/1
    • Use a small Phillips screwdriver to remove the four screws from the RAM cover. Remove the RAM cover.
    • Remove it at an angle and not straight up so you don't damage the socket.
  3. HP 15-f162dx RAM Replacement: 3 단계, 이미지 1/1
    • Using your fingers, pull the metal arms (located on both sides of the RAM stick) slightly away from it.
    • The RAM will pop up by a few millimeters.
    • Repeat steps in reverse order to reassemble the computer with new RAM
결론
Abdulrahman Bogshan
회원 가입일: 10/02/18
322 평판
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 19
전체 시간: 397
