이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Slide the latch towards the center of the laptop so the unlock emblem appears.
Place your finger on the left latch and slide it towards the center of the laptop.
Using either a credit card or flat spudger, wedge it between the palm rest and the keyboard.
Using the tool of your choice, gently pry up on the top of the keyboard.
Remove the ZIF connector that connects the laptop to the keyboard cable.
Using a Phillips #00 screwdriver, remove all the 5 millimeter screws located on the bottom of the laptop.
Using the spudger, remove the two rubber feet that are located near the battery.
Now remove the two Phillips screws that are located below the rubber feet.
다른 한 분이 해당 안내서를 완성하였습니다.
