주요 콘텐츠로 건너뛰기
HP 15-g010dx Keyboard Ribbon Cable Replacement
필요한 것
  1. HP 15-g010dx Keyboard Ribbon Cable Replacement, Battery: 1 단계, 이미지 1/1
    • Slide the latch towards the center of the laptop so the unlock emblem appears.
  2. HP 15-g010dx Keyboard Ribbon Cable Replacement: 2 단계, 이미지 1/1
    • Place your finger on the left latch and slide it towards the center of the laptop.
  3. HP 15-g010dx Keyboard Ribbon Cable Replacement: 3 단계, 이미지 1/1
    • Pull on the battery to remove.
  4. HP 15-g010dx Keyboard Ribbon Cable Replacement, Keyboard: 4 단계, 이미지 1/1
    • Remove the two 5 mm screws with the Phillips #00 screwdriver.
  5. HP 15-g010dx Keyboard Ribbon Cable Replacement: 5 단계, 이미지 1/1
    • Using either a credit card or flat spudger, wedge it between the palm rest and the keyboard.
  6. HP 15-g010dx Keyboard Ribbon Cable Replacement: 6 단계, 이미지 1/1
    • Using the tool of your choice, gently pry up on the top of the keyboard.
  7. HP 15-g010dx Keyboard Ribbon Cable Replacement: 7 단계, 이미지 1/1
    • Release the top of the keyboard.
  8. HP 15-g010dx Keyboard Ribbon Cable Replacement: 8 단계, 이미지 1/1
    • Remove the ZIF connector that connects the laptop to the keyboard cable.
  9. HP 15-g010dx Keyboard Ribbon Cable Replacement, Keyboard Ribbon Cable: 9 단계, 이미지 1/1
    • Gently lift up on the ZIF connector.
  10. HP 15-g010dx Keyboard Ribbon Cable Replacement: 10 단계, 이미지 1/1
    • Now remove the ribbon cable.
  11. HP 15-g010dx Keyboard Ribbon Cable Replacement: 11 단계, 이미지 1/1
    • Check for visible damage on the ribbon cable such as folds, kinks, or corrosion.
  12. HP 15-g010dx Keyboard Ribbon Cable Replacement: 12 단계, 이미지 1/1
    • Using your pencil's eraser, gently clean the contact points on the ribbon cable.
결승점
Christopher
회원 가입일: 10/02/18
1,162 평판
안내서 5개 작성하였습니다
댓글 2개
my ribbon cable is old, and is not making any good contact, from many times that I have repaired the system, the ribbon cable started not making good contact, because it has inside damage, you know what I mean, it went back and forth many times and it does not want to make good contact, power stops at cable, not board connector
Mitsos Tech Tips - 답글
I’m the same person, if anyone has the same problem and knows a solution just write it down, I’ll reply as soon as possible
HondaCRX -
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 10
30일 전: 54
전체 시간: 5,380
