주요 콘텐츠로 건너뛰기
HP 15-g010dx Speakers Replacement
필요한 것
  1. HP 15-g010dx Speakers Replacement, Battery: 1 단계, 이미지 1/1
    • Slide the latch towards the center of the laptop so the unlock emblem appears.
  2. HP 15-g010dx Speakers Replacement: 2 단계, 이미지 1/1
    • Place your finger on the left latch and slide it towards the center of the laptop.
  3. HP 15-g010dx Speakers Replacement: 3 단계, 이미지 1/1
    • Pull on the battery to remove.
  4. HP 15-g010dx Speakers Replacement, Keyboard: 4 단계, 이미지 1/1
    • Remove the two 5 mm screws with the Phillips #00 screwdriver.
  5. HP 15-g010dx Speakers Replacement: 5 단계, 이미지 1/1
    • Using either a credit card or flat spudger, wedge it between the palm rest and the keyboard.
  6. HP 15-g010dx Speakers Replacement: 6 단계, 이미지 1/1
    • Using the tool of your choice, gently pry up on the top of the keyboard.
  7. HP 15-g010dx Speakers Replacement: 7 단계, 이미지 1/1
    • Release the top of the keyboard.
  8. HP 15-g010dx Speakers Replacement: 8 단계, 이미지 1/1
    • Remove the ZIF connector that connects the laptop to the keyboard cable.
  9. HP 15-g010dx Speakers Replacement, Speakers: 9 단계, 이미지 1/1
    • Using the Phillips #00 screwdriver, remove the 5 millimeter screws that are visible.
  10. HP 15-g010dx Speakers Replacement: 10 단계, 이미지 1/2 HP 15-g010dx Speakers Replacement: 10 단계, 이미지 2/2
    • Using the spudger, remove the two rubber feet that are located near the battery.
  11. HP 15-g010dx Speakers Replacement: 11 단계, 이미지 1/2 HP 15-g010dx Speakers Replacement: 11 단계, 이미지 2/2
    • Now remove the two Phillips screws that are located below the rubber feet.
  12. HP 15-g010dx Speakers Replacement: 12 단계, 이미지 1/3 HP 15-g010dx Speakers Replacement: 12 단계, 이미지 2/3 HP 15-g010dx Speakers Replacement: 12 단계, 이미지 3/3
    • Remove the optical drive by pulling it out by hand.
  13. HP 15-g010dx Speakers Replacement: 13 단계, 이미지 1/1
    • Remove the two Phillips screws inside the optical drive housing.
  14. HP 15-g010dx Speakers Replacement: 14 단계, 이미지 1/1
    • Disconnect the power button ribbon cable by lifting the connector.
  15. HP 15-g010dx Speakers Replacement: 15 단계, 이미지 1/3 HP 15-g010dx Speakers Replacement: 15 단계, 이미지 2/3 HP 15-g010dx Speakers Replacement: 15 단계, 이미지 3/3
    • Disconnect the touch pad ribbon cable by lifting up on the connector.
  16. HP 15-g010dx Speakers Replacement: 16 단계, 이미지 1/3 HP 15-g010dx Speakers Replacement: 16 단계, 이미지 2/3 HP 15-g010dx Speakers Replacement: 16 단계, 이미지 3/3
    • Now remove the screws indicated by an arrow stamped into the metal, located where the keyboard was.
  17. HP 15-g010dx Speakers Replacement: 17 단계, 이미지 1/1
    • Take the metal spudger and gently insert in between the palm rest and the body.
  18. HP 15-g010dx Speakers Replacement: 18 단계, 이미지 1/1
    • Work the spudger in small increments around the palm rest while lifting it up in the air.
  19. HP 15-g010dx Speakers Replacement: 19 단계, 이미지 1/3 HP 15-g010dx Speakers Replacement: 19 단계, 이미지 2/3 HP 15-g010dx Speakers Replacement: 19 단계, 이미지 3/3
    • Carefully remove the palm rest and flip it over.
  20. HP 15-g010dx Speakers Replacement: 20 단계, 이미지 1/2 HP 15-g010dx Speakers Replacement: 20 단계, 이미지 2/2
    • Lift up on the speaker connectors to unplug the speaker cables.
  21. HP 15-g010dx Speakers Replacement: 21 단계, 이미지 1/2 HP 15-g010dx Speakers Replacement: 21 단계, 이미지 2/2
    • Remove the screws that are securing the speakers.
  22. HP 15-g010dx Speakers Replacement: 22 단계, 이미지 1/2 HP 15-g010dx Speakers Replacement: 22 단계, 이미지 2/2
    • Remove the speakers.
결승점
다른 2명이 해당 안내서를 완성하였습니다.
Christopher
회원 가입일: 10/02/18
1,162 평판
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 338
