주요 콘텐츠로 건너뛰기
HP 15-g020dx Keyboard Replacement
필요한 것
  1. HP 15-g020dx Keyboard Replacement, Battery: 1 단계, 이미지 1/1
    • Flip the laptop over so that the bottom is facing you.
    • Slide the latch towards the center of the laptop so the unlock emblem appears.
  2. HP 15-g020dx Keyboard Replacement: 2 단계, 이미지 1/1
    • Place your finger on the left latch and slide it towards the center of the laptop to remove the battery.
  3. HP 15-g020dx Keyboard Replacement: 3 단계, 이미지 1/1
    • Remove the battery from the laptop.
  4. HP 15-g020dx Keyboard Replacement, Keyboard: 4 단계, 이미지 1/1
    • Use the plastic opening tool to lift the panel with the keyboard.
  5. HP 15-g020dx Keyboard Replacement: 5 단계, 이미지 1/1
    • Take the keyboard and the section of the panel surrounding the keyboard apart.
  6. HP 15-g020dx Keyboard Replacement: 6 단계, 이미지 1/2 HP 15-g020dx Keyboard Replacement: 6 단계, 이미지 2/2
    • Lift the flip covering the connection port and remove the connecting strip to detach the keyboard from the motherboard.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Yisong Zou
회원 가입일: 10/04/19
465 평판
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 3
전체 시간: 402
