주요 콘텐츠로 건너뛰기
HP 15-g029wm Motherboard Replacement
필요한 것
  1. HP 15-g029wm Motherboard Replacement, Battery: 1 단계, 이미지 1/1
    • Unplug any charging cord or accessories connected to the device before beginning.
  2. HP 15-g029wm Motherboard Replacement: 2 단계, 이미지 1/1
    • Place the laptop bottom-side up on a secure, flat surface.
  3. HP 15-g029wm Motherboard Replacement: 3 단계, 이미지 1/3 HP 15-g029wm Motherboard Replacement: 3 단계, 이미지 2/3 HP 15-g029wm Motherboard Replacement: 3 단계, 이미지 3/3
    • Slide each of the two switches that secure the battery to the left.
    • This will reveal an image of an unlocked lock.
  4. HP 15-g029wm Motherboard Replacement: 4 단계, 이미지 1/3 HP 15-g029wm Motherboard Replacement: 4 단계, 이미지 2/3 HP 15-g029wm Motherboard Replacement: 4 단계, 이미지 3/3
    • Use your hands to gently pull the disconnected battery out of the device.
    • When inserting the new battery, pay special attention to align the battery connections correctly.
  5. HP 15-g029wm Motherboard Replacement, Upper Case: 5 단계, 이미지 1/2 HP 15-g029wm Motherboard Replacement, Upper Case: 5 단계, 이미지 2/2
    • Remove the following Phillips screws on the lower case:
    • Nine 5 mm
    • One 6 mm
    • This will allow the optical drive to separate from the chassis.
  6. HP 15-g029wm Motherboard Replacement: 6 단계, 이미지 1/1
    • Slide the optical drive directly out of its slot.
  7. HP 15-g029wm Motherboard Replacement: 7 단계, 이미지 1/1
    • Remove the two 2 mm Phillips screws on the lip of the optical drive slot.
  8. HP 15-g029wm Motherboard Replacement: 8 단계, 이미지 1/3 HP 15-g029wm Motherboard Replacement: 8 단계, 이미지 2/3 HP 15-g029wm Motherboard Replacement: 8 단계, 이미지 3/3
    • Use an opening pick to remove the two circular rubber feet near the laptop hinges.
    • Remove both of the 8 mm Phillips screws.
    • The screws were hidden by the rubber feet.
  9. HP 15-g029wm Motherboard Replacement: 9 단계, 이미지 1/2 HP 15-g029wm Motherboard Replacement: 9 단계, 이미지 2/2
    • Use an opening pick to pry up and remove the left hinge cover.
    • Use an opening pick to pry up and remove the right hinge cover.
  10. HP 15-g029wm Motherboard Replacement: 10 단계, 이미지 1/3 HP 15-g029wm Motherboard Replacement: 10 단계, 이미지 2/3 HP 15-g029wm Motherboard Replacement: 10 단계, 이미지 3/3
    • Flip the device face up and open the lid.
    • Insert an opening pick under the keyboard and pry around the perimeter of the keyboard until it fully releases.
    • Lift the keyboard slightly.
    • There is a ribbon cable connecting the keyboard to the device on the underside. Do NOT pull it away or you risk ripping the ribbon cable and causing damage.
    • Use your fingers or an opening pick to unlock the ZIF locking flap that secures the keyboard ribbon cable.
    • Disconnect the keyboard ribbon cable.
    • Lift the keyboard off.
  11. HP 15-g029wm Motherboard Replacement: 11 단계, 이미지 1/3 HP 15-g029wm Motherboard Replacement: 11 단계, 이미지 2/3 HP 15-g029wm Motherboard Replacement: 11 단계, 이미지 3/3
    • Remove two 5 mm screws using a Phillips screwdriver.
    • Insert an opening pick in the seam between the top case and chassis.
    • Slide the opening pick around the edge of the device to separate the top case from the chassis.
    • Slightly lift the top case up and away from the chassis.
    • There is a ribbon cable connecting the top plate to the device. Handle with care, and do NOT yank on the ribbon cable to prevent damage.
  12. HP 15-g029wm Motherboard Replacement: 12 단계, 이미지 1/3 HP 15-g029wm Motherboard Replacement: 12 단계, 이미지 2/3 HP 15-g029wm Motherboard Replacement: 12 단계, 이미지 3/3
    • Use your fingers or an opening pick to flip up the black ZIF locking flap.
    • Disconnect the ribbon cable.
    • Lift off the top case.
  13. HP 15-g029wm Motherboard Replacement, Fan: 13 단계, 이미지 1/2 HP 15-g029wm Motherboard Replacement, Fan: 13 단계, 이미지 2/2
    • Use a Phillips screwdriver to remove the three 5 mm screws that secure the fan.
  14. HP 15-g029wm Motherboard Replacement: 14 단계, 이미지 1/2 HP 15-g029wm Motherboard Replacement: 14 단계, 이미지 2/2
    • Gently "walk" the fan connector directly out of its motherboard socket.
    • Do not pull on the wires.
  15. HP 15-g029wm Motherboard Replacement: 15 단계, 이미지 1/1
    • Lift the fan up and out of the chassis.
  16. HP 15-g029wm Motherboard Replacement, HDD: 16 단계, 이미지 1/2 HP 15-g029wm Motherboard Replacement, HDD: 16 단계, 이미지 2/2
    • Remove the two 5 mm Phillips screws that secure the HDD.
    • Pull the HDD slightly to the right to disconnect it, then lift it up and out of the chassis.
  17. HP 15-g029wm Motherboard Replacement, Wi-Fi Card: 17 단계, 이미지 1/2 HP 15-g029wm Motherboard Replacement, Wi-Fi Card: 17 단계, 이미지 2/2
    • Use the tip of a spudger to pry up and disconnect the two antenna cables attached to the wireless card.
  18. HP 15-g029wm Motherboard Replacement: 18 단계, 이미지 1/3 HP 15-g029wm Motherboard Replacement: 18 단계, 이미지 2/3 HP 15-g029wm Motherboard Replacement: 18 단계, 이미지 3/3
    • Remove the single 3 mm Phillips screw that secures the wireless card.
    • Pull the wireless card out of its socket.
  19. HP 15-g029wm Motherboard Replacement, Motherboard: 19 단계, 이미지 1/3 HP 15-g029wm Motherboard Replacement, Motherboard: 19 단계, 이미지 2/3 HP 15-g029wm Motherboard Replacement, Motherboard: 19 단계, 이미지 3/3
    • Use two opening picks to disconnect the display cable.
  20. HP 15-g029wm Motherboard Replacement: 20 단계, 이미지 1/1
    • Use an opening pick to gently "walk" the white speaker connector directly out of its port.
  21. HP 15-g029wm Motherboard Replacement: 21 단계, 이미지 1/3 HP 15-g029wm Motherboard Replacement: 21 단계, 이미지 2/3 HP 15-g029wm Motherboard Replacement: 21 단계, 이미지 3/3
    • Remove the four 3 mm screws that secure the motherboard.
    • Lift the front edge of the motherboard slightly.
    • There is a ribbon cable connecting the motherboard to the device chassis. Do not yank it away.
  22. HP 15-g029wm Motherboard Replacement: 22 단계, 이미지 1/3 HP 15-g029wm Motherboard Replacement: 22 단계, 이미지 2/3 HP 15-g029wm Motherboard Replacement: 22 단계, 이미지 3/3
    • Use an opening pick or your fingers to release the ZIF locking flap.
    • Pull the ribbon cable out of its port.
  23. HP 15-g029wm Motherboard Replacement: 23 단계, 이미지 1/1
    • The motherboard is now fully disconnected and able to be removed from the chassis by lifting it out with your hands.
    • Remove the following components for your new motherboard: Heatsink, RAM, CMOS battery.
결론
Syrinity/Ezyra/Ezra
회원 가입일: 01/29/24
375 평판
안내서 3개 작성하였습니다
Austin Community College, Team 18-2, Watkins Spring 2024 Austin Community College, Team 18-2, Watkins Spring 2024 회원
AUSTINCC-WATKINS-S24S18G2
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 9
전체 시간: 99
